Author Topic: Model 2 cabinet with Nanao 29  (Read 2079 times)
xabi
  • Newbie
  • Last login:April 06, 2008, 02:29:06 pm
« on: April 06, 2008, 04:09:41 am »
Hi there:
I have a model 2 cabinet (See photos on flickr set: http://flickr.com/photos/xabi/sets/72157604408182529/)
And I want to connect a PC with arcadeVGA + JPac (I already have arcadevga and Jpac)
As you may known this monitor is nanao ms9-29su 15/25 Khz monitor (it has a connector high/low) in the PCB as you can see here: http://flickr.com/photos/xabi/2392015330/in/set-72157604408182529/
What's the difference betwen 15 and 25 Khz (resolution?) What's better? What's the right freq. to use with arcadeVGA and mame?
Can i Just connect (just for testing) the JPAC RGB,Ground and Sync pins to the monitor in order to try it? or must I connect more things? (note that monitor is already powered.
Does JPAC need to be powered?
xabi
« Last Edit: April 06, 2008, 04:28:47 am by xabi »
grantspain
Re: Model 2 cabinet with Nanao 29
« Reply #1 on: April 06, 2008, 05:15:22 pm »
the arcade vga card will be expecting to output a 15khz signal
this is an outstanding quality monitor btw
jpac are designed to interface a jamma cab with a pc,you have a model 2 cab so you would need to adapt the wiring quite significantly
it would be very easy to install a jamma loom in that cab,you just need some soldering skills and a little common sense
Ummon
  • Trade Count: (+13)
« Reply #2 on: April 08, 2008, 02:53:43 pm »
As well as doing some basic research to know what resolution, scanrate, refresh, etc are.
Yo. Chocolate.
Stephen Hawking
northerngames
  • Trade Count: (+18)
« Reply #3 on: April 08, 2008, 09:05:15 pm »
I run a nanao ms8-26su
you will need to run composite sync set on 15K only 25K is not needed and unwanted for what your wanting to do.
