Author Topic: Aussie Juke version 1.6.9.0 released  (Read 7950 times)
AussieJuke
  • Last login:October 18, 2011, 02:22:10 am
« on: April 04, 2008, 11:23:34 pm »
Version 1.6.9.0 of Aussie Juke has been released.
Added support for showing video clips on 2nd monitor. Also supports wmv & some avi video files.
Version 1.6.6.0 of Aussie Juke has been released.
Improved parsing of tags and file names. Added support for small / full video window. (only tested with mpeg1 files so far)
Version 1.6.5.0 of Aussie Juke has been released.
I have fixed a few bugs. Now scales correctly to non 4:3 monitors.
Version 1.6.3.0 of Aussie Juke has been released.
I have added wma support (and wma tags) and more skin options. Also fixed a few bugs.
Version 1.6.2.0 of Aussie Juke has been released.
I have added more skin options and the configuration can now be done from within the program.
« Last Edit: January 07, 2009, 04:23:49 pm by AussieJuke »
loadman
  • Last login:August 13, 2026, 03:18:08 am
  • MaLa FE developer
    • MaLa
Re: Aussie Juke version 1.6.2.0 released
« Reply #1 on: April 05, 2008, 12:04:06 am »
What? No Screenshot  :P
AussieJuke
« Reply #2 on: April 05, 2008, 01:08:35 am »
But of course there is. Check again. :P
loadman
  • MaLa FE developer
    • MaLa
« Reply #3 on: April 05, 2008, 01:18:24 am »
oh yeah
AussieJuke
Re: Aussie Juke version 1.6.5.0 released
« Reply #4 on: September 05, 2008, 09:16:04 pm »
New version. See first post.
AussieJuke
Re: Aussie Juke version 1.6.6.0 released
« Reply #5 on: December 29, 2008, 01:59:13 am »
Finally got some time for a new version. See first post.
AussieJuke
Re: Aussie Juke version 1.6.9.0 released
« Reply #6 on: January 07, 2009, 04:25:08 pm »
Added support for using 2nd monitor (TV) for video clips.
gonzo90017
« Reply #7 on: January 08, 2009, 01:36:24 pm »
Looks like a great program for Arcade Machines.
The only problem I see is having to add albums one by one.
I'll give you one example. I have one of my Hard Rock album set up like this:
H:\Genres\Hard Rock\ACDC\Albums
I I setup my Albums directory to scan the "Genres" folder nothing comes up.
But then even If I choose the ACDC folder still nothing comes up. (unless i'm not doing it right  :laugh:)
I have to click on each individual albums in order for it to be added.
It would be cool if it could scan through subfolders.
« Last Edit: January 08, 2009, 01:38:53 pm by gonzo90017 »
AussieJuke
« Reply #8 on: January 08, 2009, 07:12:35 pm »
Yes, the album directories need to be in Artist/Album/Song order. I've not tried it when that structure is deeper than those levels, but can see that it would be needed for Genres, etc. I'll see what I can do.
gonzo90017
« Reply #9 on: January 09, 2009, 12:57:49 am »
Thank you for your quick response.
One more issue.
I unzipped the file program in my Windows 98 machine. Then double clicked on the .exe.
It complained about gdiplus.dll not being present.
So I downloaded gdiplus.dll from a .dll site and all is well.
Just thought I should let you know since there might not be that many people using 98.  ;D
AussieJuke
« Reply #10 on: January 09, 2009, 05:46:27 am »
I just tried Aussie Juke with M:\Genres\Hard Rock\Artists\Albums\Songs structure and it worked perfectly.
I simply added M:\Genres\ to the Album Directories list box by browsing to it via the configuration screen.
Did you add it this way or manually edit the ini file?
As for the gdiplus dll, I had forgotten that win98 machines don't have this present by default.
It's used by one of the configuration screen components. I'll add a note in the user notes about that.  ;D
« Last Edit: January 09, 2009, 05:48:56 am by AussieJuke »
gonzo90017
« Reply #11 on: January 09, 2009, 02:36:07 pm »
I added it through the configuration screen.
AussieJuke
« Reply #12 on: January 09, 2009, 07:53:39 pm »
I'm not sure what to say. I've re-read your posts and you appear to be doing it correctly. I tried the same as you and it works.  ???
