Author Topic: Finishing off a stenciled cab  (Read 2374 times)
smac666
  • Last login:September 25, 2016, 12:40:02 am
« on: April 01, 2008, 08:52:01 am »
Hi,
I just finished painting my Defender cab and have removed the stencils. However when I run my hand down the side of the cab I can feel the lip / step where the paint has dried against the edge of the stencil. Its not a big problem but its not perfect and I was wondering if I could do something to fix it. I can think of a few things but don't really want to try them unless I mess up the paintwork.
1) I can sand the edges with a very fine grit sandpaper and then buff the whole cabinet
2) I can just buff the whole thing and try to tone down the edge sharpness.
3) I can sand the whoel cab with fine grit sand paper and then clear coat it.
Not  sure what would be the best way to proceed. Anyone been in a similar situation and found a good solution.
Steve
Re: Finishing off a stenciled cab
« Reply #1 on: April 01, 2008, 09:11:45 am »
Can you see the lips?  If you can't see it be happy and stop splitting hairs so finely.
prOk
  • Last login:December 28, 2015, 08:29:34 pm
  • www.rgvac.com
    • Brian's Classic Arcade
« Reply #2 on: April 01, 2008, 11:09:17 am »
Williams cabs should be finished with a couple coats of water based polyurethane..that will smooth out the ridges you feel..  also, if you have very distinct ridges you probably put on a bit too much paint :)
/b
smac666
« Reply #3 on: April 01, 2008, 02:20:09 pm »
In the right light you can see the ridges slightly, its not bad but its definetely there.
Ok so I thinking that I show rub it down with some very fine grit sandpaper and giev it a couple of coats of clear poly.
Steve
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #4 on: July 19, 2008, 06:16:29 pm »
Steve,
How did this turn out?  What paint method did you use with the stencils in the first place?
If I do not respond to your post in a timely manner, feel free to PM me.
