Author Topic: Wiring question...  (Read 1927 times)
JKJudgeX
  • Last login:August 24, 2008, 04:06:18 am
Wiring question...
« on: March 29, 2008, 03:08:16 am »
I have very little electronics experience, but, I wanted to ask a quick question about arcade cabinet wiring...
When you're wiring up your microswitches, you connect all "common" together and feed that into the "Ground", I've gathered...  but, what do you do when you already have a loop, and you want to add a new button?
Do you guys just run one long ground wire, or do you segment it out and daisy chain it?  Do you leave a lot of extra space?
Just looking for some info.
Ginsu Victim
  • Comanche, OK -- USA
Re: Wiring question...
« Reply #1 on: March 29, 2008, 11:07:09 am »
I just use male and female crimp connectors. I pull a female ground off a button, and plug a male connector into it, which has two wires coming off it with female connectors. I run one of the females back to the button, and the other to whatever new connection I've introduced.
stan2323
  • Last login:January 13, 2023, 06:05:19 pm
  • Major Retired USS Enterprise Commanding
    • My home page
« Reply #2 on: March 29, 2008, 11:45:53 am »
This is what I did.  I ran all the grounds to a common buss bar then ran that to the interface.  If I want to add another I just add another wire to the buss bar.  I used black to the buss bar and red to the interface.
Careful what you wish for you may get it!!
There are 10 kind of people in the world those that understand binary and those that do not!!
JKJudgeX
« Reply #3 on: March 29, 2008, 01:06:36 pm »
Awesome replies and pictures, guys... thank you...
Can I get the right kind of wire/crimp connectors at a local radio shack or should I order that from the internets?
  • Last login:March 31, 2026, 10:55:24 am
« Reply #4 on: March 29, 2008, 04:09:11 pm »
yes, and yes.
I have also found connectors at auto parts stores, such as autozone or advance auto.
Since most of the stuff on an arcade cab is low voltage, you will be surprised how much stuff you can find at a auto parts store.
« Reply #5 on: March 29, 2008, 04:15:36 pm »
You could also use piggy back connectors:
Link
Jdurg
« Reply #6 on: March 29, 2008, 06:18:04 pm »
VERY cool idea.  I may have to steal that for my CP build.   :cheers:
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
« Reply #7 on: March 29, 2008, 06:25:22 pm »
I agree.. I too, may pilfer that idea..
