Author Topic: Windows Vista Service Pack 1 Officially Released To The Public  (Read 1710 times)
Jdurg
Just in case you weren't following along at MS's website, they have officially released SP1 via Windows Update.  A caveat, however, is that SP1 will NOT appear if you have certain incompatible drivers installed on your system.  I couldn't understand why I couldn't see SP1 in Windows Update, and had to search around the help area of Microsoft to figure it out.  My Fingerprint Scanner and Audio Drivers were incompatible with SP1 but Windows Update didn't direct me to any updated drivers.  I went to the manufacturer's websites and downloaded the updated drivers.  Once they were installed, SP1 showed up for me in Windows Update.
I am currently downloading the 121.5 MB SP1 Update and should be up and running with it shortly.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
patrickl
  • Yo momma llama
    • PocketGalaga
Re: Windows Vista Service Pack 1 Officially Released To The Public
« Reply #1 on: March 23, 2008, 07:09:38 am »
I thought Microsoft said that it will show up in Windows update around mid april. It will install automatically then and they claim that it's better to wait until then unless you have some urgent problem that you need fixed now.
Updating your Windows Vista–based PC
In mid-April, SP1 will automatically download and install on Windows Vista–based PCs that have automatic updating turned on. This is the easiest and most convenient way to update a Windows Vista–based PC, and we strongly encourage using this method. You can, however, download and install Windows Vista SP1 manually from the Microsoft Download Center.
« Last Edit: March 23, 2008, 07:13:19 am by patrickl »
Jdurg
« Reply #2 on: March 23, 2008, 12:33:37 pm »
MS has prevented SP1 from showing up in Windows Update if you have certain compatibility issues with SP1 that they are aware of.  Check out this VistaBlog entry for more details;  Why SP1 May Not Show Up In Windows Update.
For me, it was because my audio driver and my fingerprint scanner driver were not compatible with SP1.  After updating those drivers, lo-and-behold SP1 was sitting there as a critical update.  For me, the download was about 122 MB and it took about an hour to install.  I couldn't understand why it was taking so long to install, but when my system finally rebooted I quickly found out.   ;D  SP1 removed about 6 GB worth of "fluff" from Windows Vista.  I now had an additional 6 GB on my system that I didn't have before.  (It may even be more since I didn't get an accurate measure of my HDD Space before the update).  I've also noticed my CPU fan kicking on less frequently, and some better overall performance.  From the breif few hours I've had with SP1, I'm pretty damned happy with it.
As for the April thing, that is when MS plans on releasing SP1 to everybody regardless of their drivers.  Basically, that is when they expect to have "Windows" versions of all the drivers out there that will be compatible.  If you're like me and don't allow MS to update your drivers for you, then you may never see the SP1 update.  So take a look at the link I gave an search for the drivers you have that may be preventing SP1 from showing up.  Once you update those drivers to compatible versions, you'll see SP1 in Windows Update.   :cheers:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #3 on: March 23, 2008, 12:59:21 pm »
OK Cool. Weird that they don't make that clear on their own Vista SP1 page.
I have a Dutch version of Vista so I will have to wait a while anyway. They don't even mention a date  :-\
Jdurg
« Reply #4 on: March 23, 2008, 03:22:19 pm »
Yeah, it was pissing me off that I couldn't figure out why I couldn't see SP1 via Windows Update.  I wish MS would explain this on their Windows Update page.  E.G. say "SP1 is not available for you to download due to.....".
For the languages which they haven't released yet, they will apparently be out sometime in April.  Thus far, however, I think it will be worth the wait.   :cheers:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
gonzo90017
« Reply #5 on: March 23, 2008, 07:42:16 pm »
I'm still waiting for the official realease of XP SP3.  :soapbox:
