Author Topic: Dotronix dsv25c monitor  (Read 3032 times)
billpa
  • Last login:October 01, 2017, 11:25:31 pm
« on: March 20, 2008, 02:00:55 pm »
Hi,
The company next door to ours has a video wall they are getting rid of. Probably half of the tubes are brown but there is at least 4 or 5 that look pretty good. They have a DB-9 connector in the back and can be driven by an external rack mounted board that takes composite (yuck) and "s-vhs" which seems to be similar to S-video (2 separate video streams).
So I am curious...is this a monitor that I can just plug a vga cable into and go or do I have to hack a vga to a db-9? Im guessing that its a 640 by 480 monitor but I could be wrong. The owner of the company is out for a couple of days so I wont be able to talk to him until next week.
Bill
Clu
  • Last login:January 10, 2013, 12:34:22 am
  • Watch it, sucker.
Re: Dotronix dsv25c monitor
« Reply #1 on: March 20, 2008, 10:32:04 pm »
That's how I got mine.  A local ebay auction had the whole package - image processor and 9 monitors - for $200.
How much are they asking?  I ended up selling just the processor on ebay for $200, so anything around that would be a good deal.
You will have to hack a vga cable.  You'll also have to use arcadeos or an arcadevga card.
billpa
« Reply #2 on: March 20, 2008, 10:44:53 pm »
I have no idea what he will ask but it wont be much. Im thinking around 20-25 per monitor. Quite a few have bad tubes ie brown but there are a handful of good ones. I was thinking of grabbing one and a spare. I was planning on hacking the vga cable to a db9 cable and then using powerstrip or soft15khz.
Did you use any of your monitors in your cabs yet? How did you mount them? I definitely cant fit the whole enclosure in so I will be pulling the tube and chasis out
Cheers,
Bill
andiamo-racing
  • Last login:August 05, 2012, 07:08:57 pm
« Reply #3 on: March 20, 2008, 11:12:15 pm »
The manual for that monitor is on the GGG site under the video card/monitor section in PDF format.  :cheers:
Clu
  • Watch it, sucker.
« Reply #4 on: March 21, 2008, 12:52:32 am »
I haven't got around to using it yet.  I might list a few on craigslist and see if anyone wants one.  Mame looks so nice on these I don't have the heart to toss them.
That's a bummer you have to remove the tube.  I really like the fact that they are enclosed - easier to handle.
BASS!
  • Just have fun.
« Reply #5 on: June 06, 2008, 02:09:44 am »
Hey this is an old post but very relevant to something I'm working on at the moment. I have a dnrIV  which looks the same in all the specs as the ones you guys have. The only issue with the one I picked up is that the chassis that it has only accepts coax and composite video. I would love to get vga up and going on this monitor but am unable to find anyone who has these chassis that aren't already blown up. I was wondering if you either would like to part with the chassis off one that has a bad crt or something of the like.
If not, any information on a compatible chassis for this crt would be extremely appreciated.
Specs on mine
Rca Picture tube model: a68adt25x02
Serial number d-scjt5120
9 pin neck
Vertical impedance 5.4ohm
Serial number on chasis 5050005598
