Author Topic: setup for marble madness  (Read 4711 times)
stan2323
  • Last login:January 13, 2023, 06:05:19 pm
  • Major Retired USS Enterprise Commanding
    • My home page
« on: March 16, 2008, 09:36:55 pm »
I need some help from someone who is smarter them me.
I am trying to set up Marble Madness with the track ball.  What is values that should go in for the list below.   I have tried all kind of mouse X, mouse X+, mouse X-, mouse Y, mouse Y+ and mouse Y- but the marble moves slow even when I spin the track ball fast.  If I use the defaults joystick settings it goes very fast.
Track X Analog
Track X Dec
Track X Inc
Track Y Analog
Track Y Dec
Track Y Inc
Careful what you wish for you may get it!!
There are 10 kind of people in the world those that understand binary and those that do not!!
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
Re: setup for marble madness
« Reply #1 on: March 16, 2008, 09:50:20 pm »
01111001011011110111010100100000011010000110000101110110011001010010000001110100011011110010000001100001011001000110101 00111010101110011011101000010000001110100011010000110010100100000011000010110111001100001011011000110111101100111001000 00011100110110010101101110011100110110100101110100011010010111011001101001011101000111100100100000011010010110111000100 00001110100011010000110010100100000011000010110111001100001011011000110111101100111001000000111001101100101011101000111 01000110100101101110011001110111001100100000011010010110111000100000011011010110000101101101011001010010000001100010011 11001001000000111000001110010011001010111001101110011011010010110111001100111001000000111010001100001011000100010000001 11011101101000011010010110110001100101001000000111010001101000011001010010000001100111011000010110110101100101001000000 110100101110011001000000111001001110101011011100110111001101001011011100110011100101110
Xb0x3r
  • Last login:August 06, 2010, 07:47:33 pm
« Reply #2 on: March 16, 2008, 10:07:14 pm »
When you press TAB in MAME there should be something in the list called "Analog Controls" I think. Then you can change the sensitivity of the X and Y of the trackball. I can upload some pictures upon request.
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #3 on: March 16, 2008, 10:08:40 pm »
01111001011011110111010100100000011010000110000101110110011001010010000001110100011011110010000001100001011001000110101001110101011100110111010000100000011101000110100001100101001000000110000101101110011000010110110001101111011001110010000001110011011001010110111001110011011010010111010001101001011101100110100101110100011110010010000001101001011011100010000001110100011010000110010100100000011000010110111001100001011011000110111101100111001000000111001101100101011101000111010001101001011011100110011101110011001000000110100101101110001000000110110101100001011011010110010100100000011000100111100100100000011100000111001001100101011100110111001101101001011011100110011100100000011101000110000101100010001000000111011101101000011010010110110001100101001000000111010001101000011001010010000001100111011000010110110101100101001000000110100101110011001000000111001001110101011011100110111001101001011011100110011100101110
you have to adjust the analog sensitivity in the analog settings in mame by pressing tab while the game is running.
stan2323
    • My home page
« Reply #4 on: March 16, 2008, 10:15:33 pm »
I have tried to change these values with no luck.  I do not know what # to try :dunno.  I doubled the # and then cut them in half, no luck.  What should the sensitivity be for Marble Madness?  The trackball works great for other game and as a mouse in Windows so did not think that would be a problem :dunno.
« Reply #5 on: March 16, 2008, 11:11:52 pm »
Can you provide some more detail?  Perhaps what brand trackball you are using and what version of MAME you are using.  CPU speed would help too.
That way if other users have similar setups then can tell you what theirs is set to.
~  DeLuSioNaL
stan2323
    • My home page
« Reply #6 on: March 17, 2008, 09:04:57 am »
~  DeLuSioNaL
Another part of the problem.  I do not know what info you need to make a recomendation.  I thought that the #s would be the same for each game and would not depend on the computer.
I have a HAPP 3 in trackball hooked up USB to a hud that has 2 GP-WIZ MAX 32 also hooked up.  It is a Gateway Laptop.  The processor is an AMD Athlon 64 at 2.93 GHz with 1 GB RAM.  Windows XP Home using EasyMame 5.6.6 as the front end, and Mame 0.123.
ids
  • Fighter Captured
« Reply #7 on: March 17, 2008, 12:03:36 pm »
[I do not know what info you need to make a recomendation.
They key would be the type of trackball, how it's connected (direct usb/ps2, through an optical encoder, etc)....
I tried to get a collection of this type of data going: http://forum.arcadecontrols.com/index.php?topic=77375.0
but nobody was interested :cry:
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: March 17, 2008, 03:33:12 pm »
First off, I crossed off the stuff you should not see in your input mapping for MM.  Map as follows:
Track X Analog    Mouse X
Track X Dec --- (aka: NO mouse anything)
Track X Inc ---
Track Y Analog    Mouse Y
Track Y Dec ---
Track Y Inc ---
The -Dec and -Inc lines are for non-analog inputs (like your keyboard).  If you map your mouse to these, mame will treat the mouse as a digital input and suck.
Then worry about the sensitivity mentioned in prior posts.
Robin
Knowledge is Power
stan2323
    • My home page
« Reply #9 on: March 17, 2008, 06:27:28 pm »
Track X Inc ---
Track Y Dec ---
Track Y Inc ---
Thanks.  That fixed it.  Once I got rid of the DEC and INC it works the way it should.  I did try changing the sensitivity again and I can tell the difference, much better.  Thanks
