Author Topic: hantarx 25 black line Problem Solved!!!!  (Read 1858 times)
john_abey
  • Last login:September 07, 2011, 03:51:12 pm
« on: March 15, 2008, 11:38:31 pm »
95 midway wrestle mania
wired a jamma fingerboard to monitor and sound
would like some if a sync issue or another problem
wired sync with wires twisted together
not separate
<a href="http://s246.photobucket.com/albums/gg98/john_abey/?action=view&current=DSC01564.jpg" target="_blank"><img src="http://i246.photobucket.com/albums/gg98/john_abey/DSC01564.jpg" border="0" alt="arcadesplitscreen"></a>
« Last Edit: March 18, 2008, 11:54:57 am by john_abey »
grantspain
  • Last login:Today at 03:58:19 am
Re: hantarx 25 black line
« Reply #1 on: March 16, 2008, 06:01:39 am »
what model number hanatarex? polo 1,polo2 ?
my bet this is a polo 1 chassis which is cga(15khz) and you have connected it to a pc which vga(31khz),thats why you have 2 pics
maybe read this
http://forum.arcadecontrols.com/index.php?topic=66402.0
john_abey
« Reply #2 on: March 16, 2008, 12:34:55 pm »
thanks for your quick reply grantspain :cheers:
i am using soft 15 with nvidia gforce 5200 and nvidia drivers only have 15kHz installed
res set to 600 x 480
polo 25" serial# 40029
twisted the sync wires together to make composit should I rewire and use both sync wires
to there own spot on monitor. ???
checked VGA cable pinouts a couple of times check finger board there is continuity to the monitor
no video amplifer just using 1 volt video signals
if there is anyymore info needed please just ask
thanks in advance
grantspain
« Reply #3 on: March 16, 2008, 12:42:56 pm »
if you connect a standard jamma game it will work,
the monitor is still recieving the wrong frequency which why you have two pictures
i am not familiar with the soft 15khz stuff but i can see its not a sync wiring problem as if it were your picture would be rolling or just a mess
i would say you need to check the soft 15k/vga card set up again just to make sure everything is set correct
perhaps it would be better to repost this as question regarding your particular graphic card and setting with soft 15khz
sorry i can't help more but this is a different area to what i am used to
good luck
john_abey
« Reply #4 on: March 18, 2008, 11:51:37 am »
thanks for all the help
problem solved
new drivers from nvidia version 90  installed reboot   fit screen perfect no adjustment at all
 :applaud: :laugh2: :cheers:
