Author Topic: New Member - 1st Project Donkey Kong Restoration Multicade  (Read 3543 times)
dfmassi
  • Last login:August 30, 2019, 10:41:22 am
« on: February 26, 2008, 10:00:24 am »
I recently discovered this forum and have greatly enjoyed looking at all the completed projects - so I'd thought I would share my 1st cabinet.  I purchased this Donkey Kong 3 cab for $50.  It was in bad shape.
dfmassi
Re: New Member - 1st Project Donkey Kong Restoration Multicade
« Reply #1 on: February 26, 2008, 10:02:47 am »
After I stripped her.  Note the damage from the lock bar.  The coin mech weren't much better.
dfmassi
« Reply #2 on: February 26, 2008, 10:04:08 am »
After a lot of Bondo and three coats of primer.
dfmassi
« Reply #3 on: February 26, 2008, 10:05:59 am »
And here is the final product.   Work to completion - approx 5 weeks
« Last Edit: February 26, 2008, 11:24:51 am by dfmassi »
dfmassi
« Reply #4 on: February 26, 2008, 10:07:16 am »
I modded the control panel with a second button required for the multicade games.  I wanted to keep the look as original as possible.
dfmassi
« Reply #5 on: February 26, 2008, 10:18:08 am »
A couple more pics during the work in progress.  3 coats of DK Blue  :)
golfboyusa
  • Last login:October 12, 2018, 12:44:25 pm
  • Kinda tired....think I'll go home now.....
    • Ted's Arcade
« Reply #6 on: February 26, 2008, 10:25:50 am »
Well done! My favorite game. I take it you mame'd it somehow? Or is the cabinet just running DK?
dfmassi
« Reply #7 on: February 26, 2008, 10:31:09 am »
It's running a 48-in-1  ::)  You can see the menu in this pic.
IG-88
« Reply #8 on: February 26, 2008, 03:11:28 pm »
Got a closer pic of the CP?
-HarumaN
  • Last login:August 21, 2026, 02:12:06 pm
« Reply #9 on: February 26, 2008, 04:20:01 pm »
Very nice job!  How did you paint it?  Spray?  Rollers?  It came out great.   :cheers:
dfmassi
« Reply #10 on: February 27, 2008, 03:47:30 pm »
Here's a close up of the CP.
4 coats painted with 3" cabinet roller.   Hand sanded between each coat.
ptpeter
  • Last login:December 14, 2009, 10:39:57 pm
« Reply #11 on: March 25, 2008, 11:26:52 pm »
looks awesome, I'm in a very similar situation (i have a smb cab) and am not sure if im going to restore or make it into a dk. Would you be willing to tell me the color code for that blue paint? i've been searching for a while for that color match. Also, did you prime right over the old color? if so what primer? oh yeah, one more thing, oil based or laytex paint? thanks
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #12 on: March 25, 2008, 11:46:02 pm »
The search function is your friend.
From this topic:
http://forum.arcadecontrols.com/index.php?topic=55232.0
Ok, I found the old can. It is Lowes Enterprise  Oil Semi-gloss enamel. On the can the base is 4 1134.
One the printed label:
Base:
 B 4-47865
Quart:
Color 101- 1 shot
          102- 25 shots
           103- 7 shots
           113- 2 ounces, 13 shots, 1 1/2 shot
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
