Author Topic: Wells-gardner K7500 and NeoGeo question  (Read 3162 times)
lb
  • Last login:May 21, 2003, 05:53:47 am
« on: May 20, 2003, 07:11:18 am »
hey all,
I have a wells-gardner k7500 currently hooked up to my neo-geo mvs board. The problem is that when i turn on the cabinent the monitor's frequency looks all wavy (the picture)
what is there that i could do,
i know that the monitor came with a wiring adapter that i took off the monitor and plugged in the old neo geo one......
any help would do
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:Wells-gardner K7500 and NeoGeo question
« Reply #1 on: May 20, 2003, 05:45:56 pm »
If it only happens when you first turn the monitor on, just let the monitor warm up first before you use it.
lb
« Reply #2 on: May 21, 2003, 05:57:19 am »
Ok,
So I found that the composite cable was in the ground? and the ground was in the composite spot for the monitor, so i swapped them and everythign turned out fine....allmost.
the almost part is that i get not one image, but three overlapping images to appear on the screen, and the red, green, and blue lines appear to be staggered.  I did a service test and the crosshatch lines are white  and straight for the horizontal lines, and i get very wavy vertical white lines? what should i do?
i found the H-HOLD on the monitor pcb board and adjusted it the closest i could, but still no prevail, nothing seems to line up those damn lines and fix the image, i also switched neo geo boards to see if it was the board, still no good. please help.
« Last Edit: May 21, 2003, 06:05:10 am by lb »
Darth Nuno
  • Last login:May 08, 2024, 04:26:02 pm
  • Namco is God !
    • Arcade Lifestyle / Dragon's Lair Fans
« Reply #3 on: September 25, 2004, 03:52:52 pm »
I have the same problem than you. Mine is a Wells Garnder 27K7501.
Here's the problem :
the 3 primary don't converge on the edge of the screen :
closer :
Look the white border lines... and the ghost lines :-(
with a white background :
here it's suppose to be while lines :
It's worse when i have red text ( see the ghost text ) :
I'm affraid there is no issue at this problem. I check every harware setting, even the 6 rings on the back of the CRT.... My brother is a TV technician, he inspect it, and goes to the following conclusion : change the whole CRT :-( too bad...
Ken Layton
  • Guru
  • Technician
« Reply #4 on: September 26, 2004, 12:22:14 am »
The picture tube needs to be rejuvenated. If that doesn't help then you need a new picture tube.
Neo Geo is a standard res game not medium res. All the Neo's I've seen had mostly Wells 25K7191.
You should not have a medium res k7500 in it.
exibar
  • Last login:January 02, 2025, 11:38:59 pm
  • I'm the creator of Exibar's Lair!
« Reply #5 on: September 26, 2004, 12:54:26 pm »
  How can someone rejuvenate a picture tube?  Do you have to send it somewhere?
 Mike B
Ken Layton
  • Guru
  • Technician
« Reply #6 on: September 26, 2004, 01:36:35 pm »
Take the monitor to a tv repair shop and tell them the picture tube needs to be rejuvenated. Should cost around $50.
