Author Topic: Quick Zip program question  (Read 2244 times)
« on: February 12, 2008, 11:50:40 am »
Anyone know of a zip program that I can use to zip up a bunch of files, but into a bunch of corresponding zip files (as opposed as all going into one zip file)?  I suppose some kind of batch process is probably neccesary?
Cheers!
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Quick Zip program question
« Reply #1 on: February 12, 2008, 11:53:39 am »
Pkzip ?
i think you can do a commande like
pkzip *.*  *.zip
or something close.
ahofle
    • Arcade Ambience Project
« Reply #2 on: February 12, 2008, 12:09:02 pm »
Yeah a batch file would probably be easiest.
Something like this:
for %%b in ("*.*") do pkzip %%b
« Reply #3 on: February 12, 2008, 12:53:59 pm »
Thanks for the replies...the 'zip *.* *.zip' method doesn't generally work (doesn't like the *.zip).  I just found a trial version of something called 'Batch Zip Toolkit' which does the job nicely tho :)
unclet
« Reply #4 on: February 12, 2008, 01:05:24 pm »
Perhaps FilZip can do this ..... it is free
gonzo90017
« Reply #5 on: February 12, 2008, 01:15:47 pm »
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #6 on: February 13, 2008, 12:32:51 pm »
I do this all the time - and WinRar does the job just fine.
Select all the files you want to zip, right click (assuming you have winrar shell integration, which is the default).
Select "Add to archive..." to bring up the options.
Select Archive format to "Zip" if you want that instead of RAR
Click on the "Files" tab, and then tick the checkbox "Put each file to seperate archive"
Hit Go, and you are done, every file zipped into to its own archive, named after the filename.zip.
NB This works for whole directories too, so you can move whole dirs into their own archive.
« Reply #7 on: February 14, 2008, 07:32:46 am »
Thank guys, romzipped looks good, and thanks for the tip Silver - I didn't realise I could do that!
