Author Topic: Help with MAME Compiler  (Read 2258 times)
mscromer
  • Last login:March 11, 2009, 12:49:35 pm
« on: February 01, 2008, 06:35:47 pm »
My first question is, when I choose a diff and hit the apply patch button and it scrolls through all these lines of text do I then choose another diff to apply or do I have to do each one one at a time.
My next question is after I hit the apply patch  button and it scrolls through all these lines of text I then hit the go button and it brings up the mamecompiler/mame folder. Then What? I have searched all over this forum to try to find the answer before I posted this question. I know Im missing a step cause I dont see how hitting go does anything to MAME. HELP!!! :banghead:
headkaze
  • Last login:May 01, 2026, 04:33:46 pm
  • 0x2b|~0x2b?
Re: Help with MAME Compiler
« Reply #1 on: February 01, 2008, 07:01:21 pm »
1) Choose a diff, then hit apply, choose a diff, then hit apply etc. until you have them all applied.
2) Do you have the Mame source code in C:\Program Files\MameCompiler\Mame?
It would help if you pasted the output in your post if you encounter an error again. The output should give you an idea of what your doing wrong.
mscromer
« Reply #2 on: February 01, 2008, 07:15:30 pm »
I do have the source code in the mamecompiler\mame folder.
In the Compile output window it says this
Compiling mame
mingw32*make ***no targets specified and no makefile found stop
Finished
headkaze
  • 0x2b|~0x2b?
« Reply #3 on: February 01, 2008, 07:24:00 pm »
Compiling mame
Finished
That error means you don't! Are you sure it's the source code and not the binary? There are two downloads from mamedev.org one is the binary and one is the source. You need the source!
mscromer
« Reply #4 on: February 01, 2008, 07:31:55 pm »
I thought I had the source. Ill try again. When I do get it do I unzip it into the correct folder?
Two more questions:
Can you explain clean compile and disable werror.
« Last Edit: February 01, 2008, 07:38:11 pm by mscromer »
mscromer
« Reply #5 on: February 02, 2008, 04:48:05 pm »
I d\l the source code and unzipped it in the mamecompiler\mame folder, but Im getting these errors now
src/mame/drivers/atarig1.c:74
src/mame/drivers/atarig1.c:68
src/mame/drivers/atarig1.c:80
src/mame/drivers/atarig1.c:185
src/mame/drivers/atarig1.c:177
src/mame/drivers/atarig1.c:193
mingw32-make[obj/windows/mame/drivers/atarig1.0]error1
