Author Topic: Router - Bushing question  (Read 4221 times)
pie taster
  • Last login:April 03, 2015, 09:21:51 am
« on: January 30, 2008, 01:47:39 pm »
neewb question here.
I have a 1/2" straight shank for my router.. and I got a bushing ring (template thing, i think i'm calling that right).  That has a 5/8" opening.
I want to route out some cp stuff and when i tested the shank in the hole.. (by hand).. IT WAS TIGHT... so tight that i was afraid to stick it in my router and turn it on.
I then started think is it too small of an opening?
If i start routing and if the shank bends or something.. am i risk of screwing up 1) my shank (bad) 2) my router (real bad) 3) my jimmie!  (HORRIFIC!!).
or.. am i good and it won't be a problem.
or.. don't be dumb.. get a bigger hole!
sstorkel
  • Last login:November 08, 2011, 09:04:03 pm
Re: Router - Bushing question
« Reply #1 on: January 30, 2008, 02:09:51 pm »
Why do you think you need a template bushing in the first place? Unless you have jigs that were designed to be used with a 5/8" template bushing. I'm not sure what you're gong to use it for...
That said, do not use a 1/2" bit with a 5/8" bushing!
Here's why: a 5/8" template bushing does not have a 5/8" hole in it! The 5/8" measurement represents the outside diameter of the bushing. The hole that goes through the center of the bushing is actually smaller. Probably much smaller. Even if the hole was 5/8", that only leaves 1/16" clearance around the outside of a half-inch bit. Ideally you want more clearance. Probably a lot more, especially if you aren't using a centering cone to ensure that your bits are perfectly centered in the template bushing's hole.
pie taster
« Reply #2 on: January 30, 2008, 02:29:46 pm »
Well i was going to make the jigs as talked about in this sticky thread.
How to make a Top Mount or Under Mount Joystick Jig
But yes.. thanks for the tip on getting a bigger one.. I was worried about that!
pie taster
« Reply #3 on: January 30, 2008, 02:40:48 pm »
sstorkel
« Reply #4 on: January 30, 2008, 03:10:12 pm »
How big of bushing ring should I get for a 1/2" shank bit?
I was thinking of this one...
http://www.amazon.com/Porter-Cable-42030-General-Routing-Templet/dp/B000056OOZ/
or this one..
http://www.amazon.com/Porter-Cable-42039-General-Routing-Templet/dp/B000056OP0/
Either of those will work. So will this one, I think.
If I were you, I'd think about whether you want to buy a new template collar or a new bit. Remember, with a 1/2-inch bit you're stuck with a 1/4-inch corner radius (e.g. about the size of a U.S. quarter). Depending on your joysticks and how snug a fit you want, this might be fine. Or it might be too large. My tendency would be to use a smaller bit, to get a tighter radius on the corners. Maybe a 1/4-inch or 3/8-inch bit?
