Author Topic: XBOX lightgun  (Read 3882 times)
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
XBOX lightgun
« on: January 16, 2008, 11:04:33 pm »
I'm running MAME on my PCI want to play Area 51 with my XBOX lightgun. I own the device which connects the XBOX controller to the PC and I also downloaded and properly installed XBCD driver. Needless to say, my XBOX controller works fine in MAME. But now I want to use my XBOX lightgun. Plugged it in and Windows recognizes it by installing XBCD automatically. But I don't know how to make it so MAME reads my lightgun? Can someone please help me? Thanks in advance.
heemid
  • Last login:December 04, 2015, 01:02:18 pm
Re: XBOX lightgun
« Reply #1 on: January 26, 2008, 11:51:50 am »
Wont work, there is no way to pass the scan lines. If you cut the xbox cord you will see a red, green, black, white, and yellow wire. The usb adapter will not support the yellow wire. Get a guncon and an adapter or a lcd topgun.
alienware32
Re: XBOX lightgun
« Reply #2 on: January 26, 2008, 12:12:11 pm »
can you suggest a cheaper alternative
