Author Topic: Can i plug a video rca to a PC monitor ?  (Read 4605 times)
janey6152
  • Last login:April 02, 2025, 09:49:52 pm
« on: December 20, 2007, 10:27:14 am »
I have a plug in play game. I want to make a bartop and not have to use a PC borad  Such as Mame .
just wanna  take it apart and plug it into a PC monitor , Is the an adapter to do this ????
ahofle
    • Arcade Ambience Project
Re: Can i plug a video rca to a PC monitor ?
« Reply #1 on: December 20, 2007, 11:13:23 am »
There are converters that do this.  Here is one that has VGA output (no idea what the quality would be like though).
shardian
« Reply #2 on: December 20, 2007, 11:20:21 am »
My old IBM PC had a monitor which also had RCA plugs in the back. I used that monitor for my Genesis/32x back in the day. Nowadays, I have no clue how that was done. I do wish I still had that monitor though. ;D
So I guess my advice is hit the junk stores looking for ancient pc's and look at the back of the monitors for RCA plugs.
knave
  • Last login:March 24, 2026, 03:52:12 pm
« Reply #3 on: December 20, 2007, 12:28:28 pm »
I have an old commidore monitor that also has rca plugs...I still use it as a back up for my consoles...I think it has RGB inputs as well...so I could use it as an arcade monitor too.
My question to you is: Why not use a 13" TV? I'm pretty sure you could find one cheap or free.  If you want a bigger Bartop use a 19" or 20" TV.  Most likely any TV you picked up would be cheaper than the converter from the link above.
I've looked for the same device in order to use a cheap 19 or 20" LCD monitor with my Plug and play.  This is the most inexpensive one I've seen.  Usually they are $80 or more.
Expect VCR quality Video.
janey6152
« Reply #4 on: December 20, 2007, 05:58:28 pm »
reason why i ask is i have about 10 pc monitor sitting around doing nothing.
so i fig i could make some mame, plug n  play  with them...
whatzcrackn
  • Last login:January 19, 2019, 12:14:02 pm
  • U just won tickets to da 'GUN SHOW'
« Reply #5 on: December 20, 2007, 07:03:10 pm »
goto ebay and type in vga box, you will get a lot of options.  You might be able to hook up consoles to if you have them!!
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #6 on: December 20, 2007, 08:43:16 pm »
Those aren't multi-sync monitors. Big difference between PC monitors and arcade/tv/C64 style monitors.
Composite to multi-sync convertors cost too much. You're better off just finding cheap used 13" televisions.
NO MORE!!
knave
« Reply #7 on: December 21, 2007, 11:44:34 am »
Ah, you're totally right...It has no vga input.  Not that I'd want it...the resolution is too low for any real computing...I was just trying to think of monitors with rca plugs...
