Author Topic: How do I get more materials in 3DS max...  (Read 3156 times)
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« on: May 11, 2003, 11:39:51 am »
I have a little experience with this program, but for the life of me I can't figure out how to get more than like 24 materials at a time in my material pallete.  I would think there'd be a way to have dozens  and dozens or hundreds of materials at a time....am I just missing something?  Any insight appreciated   :)
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
Re:How do I get more materials in 3DS max...
« Reply #1 on: May 11, 2003, 11:56:46 am »
that is your active pallette...you can switch them at any time with materials from your material librarys or from the scene...look at them as a selection of all the materials available...
peter
Frostillicus
  • Arcade Artist
« Reply #2 on: May 12, 2003, 05:32:53 am »
Oh.  that makes sense - I messed with it a bit and I think I have it now..
« Reply #3 on: May 12, 2003, 02:02:26 pm »
Just in case you are thinking of making cabinet models for 3darcade.... some guidelines.....
Marquee and screenshot polys should be at the top of your object hierarchy.
Each material (and material map and sub material ect...) you use MUST have a unique name.  By unique I don't just mean unique to the other materials used in that model, I mean unique in regards to any possible material ever used on any model displayed in 3darcade.  So your best bet is to name them after the model... (like sf2-black instead of just black).
These rules also apply to may other engines, so I was just giving a heads up.  Good luck.
caykroyd
  • Last login:March 07, 2007, 06:53:45 pm
« Reply #4 on: May 12, 2003, 03:23:10 pm »
I'm thinking about modelling in 3DStudio.  What is the basic concept?  Do you draw out you individual pieces of wood, then rotate and connect them, etc.  Or do you draw it out as a whole?
« Reply #5 on: May 12, 2003, 03:53:35 pm »
depends upon the cabinet..... usually I use the line tool to make the profile of a side, extrude it to 3/4 inches, clone it and move the clone to the right to set the width of the cabinet.  Then i start filling in the middle with the control panel being made seperately in many cases.
Frostillicus
  • Arcade Artist
« Reply #6 on: May 13, 2003, 07:49:02 am »
That's kind of how I did it, too.  Though I used Illustrator to make the splines and lofted them.   I was using a 3/4" path when I guess I could have extruded it and just specified .75 inches.  The whole thing was a learning process for me - that program is waaaay more complicated than anything else I've used.
But I think I did fairly well Example (this took forever to make, BTW  ;) )
It is a great way to visualize what it will all look like, and to see if all the parts will fit.
)p(
« Reply #7 on: May 13, 2003, 08:54:23 am »
looks good  :D
if you want try to let it show up in 3darcade in addition to what hc mentioned about the material names use group to uhm group all meshes together and give it a unique name then export it to w3d using the groupname.
for more info and export settings see:
http://3darcade.mameworld.net/frontend/fereadme.htm#Arcades
max w3d exporter can be found here:
http://3darcade.mameworld.net/3ds_maxr4_exporter.zip
copy and paste link
peter
GSXRMovistar
  • Last login:May 09, 2026, 06:52:57 pm
  • Gez, this is gonna be expensive!
    • forum.arcadecontrols.com/index.php/topic,148135.0.html
    • CoffeeCade
« Reply #8 on: May 13, 2003, 10:42:51 am »
My cabinet was also designed in Max, think I may give that exporter a try, would be nice to see my cabinet in Emulaxian.
)p(
« Reply #9 on: May 13, 2003, 11:04:32 am »
one more thing that might be helpful... I used generic units but as a metric system so 180 units will be 180 cm or 1.80 meter
peter
