Author Topic: shutdown by one button?  (Read 2258 times)
badkitty
  • Last login:September 17, 2008, 07:17:31 pm
« on: November 29, 2007, 04:52:58 am »
i found the way to create shortcut on desltop to shutdown pc with one click.  what i want to know is if there is a way to assign a keystroke for that purpose.
    i have an exit button on my CP which is the escape key, if someone presses it it exits Mgalaxy (with confirmation) then goes to desktop, id like to be able to press it one more time to goto straight to window shutdown.  possible ?
"They key to immortality, is first living a life worth remembering." - St Augustine
patrickl
  • Yo momma llama
    • PocketGalaga
Re: shutdown by one button?
« Reply #1 on: November 29, 2007, 05:22:35 am »
If you right click the shortcut and select properties, you can set the shortkey for that shortcut. It needs to be a CTRl+ALT combination and the ESC key is not allowed.
TOK
  • The Game Always Wins
« Reply #2 on: November 29, 2007, 06:05:02 am »
Windows XP has the option if you go into Control Panel ->Power Options->Advanced.
You'll see a drop down that says "When I press the power button on my computer:"
You can set that for shut down.
I cut the power connector leads and wire them to a momentary button put in an inconspicuous place on top of the cabinet. I prefer a smaller, recessed button, but you can even use an arcade button if you want.
Its a little more work than your shortcut, but it gives you one button power up and down.
badkitty
« Reply #3 on: November 29, 2007, 12:01:40 pm »
cool. DUH!!  lol
i already have the PC power on and PC reset ran to arcade buttons inside my CP, Next to my main cab power switch and TV remote.
« Last Edit: November 29, 2007, 12:04:28 pm by badkitty »
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #4 on: November 30, 2007, 03:17:25 am »
Try this
http://forum.arcadecontrols.com/index.php?topic=28959.0
Just change "hibernate" to "shutdown".
badkitty
« Reply #5 on: November 30, 2007, 03:56:50 am »
i havent tried it yet...but does the power button to shutdown  method just power down PC  without shutting windows down first ?   i dont want to start up cab and see the safemode thing everytime
bfauska
« Reply #6 on: November 30, 2007, 04:15:18 am »
When you tell windows to shutdown from the power button it does a regular shutdown, it will boot up normally after.
badkitty
« Reply #7 on: November 30, 2007, 01:11:19 pm »
ok.just wasnt sure if it was the same as HOLDING The power button and the it powers off instantly.   thanks guys
