Author Topic: Rounding corner....best way?  (Read 1484 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: May 09, 2003, 03:33:53 am »
What's the best way to round corners on my side panels...especially the dramatic curves up by the marquee?  Sand paper  :-[?
Best Kid iPad Apps
skirge66
  • Last login:June 03, 2003, 06:25:58 am
  • the stupid will normally punish themselves
Re:Rounding corner....best way?
« Reply #1 on: May 09, 2003, 03:55:16 am »
i first drew the lines out with a compass, made a jig to fit my router, used an 1 1/2" plunge bore bit for my router, the sanded it.
skirge66
Diplomacy is the art of saying "nice doggy" until you find a bigger rock to throw
ErikRuud
  • Last login:March 23, 2026, 07:42:27 pm
« Reply #2 on: May 09, 2003, 09:52:17 am »
Here are some options
1) Use router or Roto Zip and jig or guide as mentioned above.
2) Use a jig saw to cut close to the line of the curve and the a power sander to sand down to the line. A belt sander or contour sander would be best.  A  palm or orbital sander would have trouble with the inside curves.
3) Anything else would probably be too much work to consider.
American Laser Games Wrapper
O2em Rom Utility
GSXRMovistar
  • Last login:May 09, 2026, 06:52:57 pm
  • Gez, this is gonna be expensive!
    • forum.arcadecontrols.com/index.php/topic,148135.0.html
    • CoffeeCade
« Reply #3 on: May 09, 2003, 09:58:44 am »
Easiest way is to draw your curves on your panels then sand the corners by hand, it takes a little longer than using power tools but you shouldn't end up making any mistakes.
