Author Topic: jpac 24kHz  (Read 1993 times)
brendz
  • Last login:May 24, 2012, 09:28:49 am
jpac 24kHz
« on: November 12, 2007, 06:46:14 pm »
i have a dual rez 29" nanao monitor in a new astrocity cab being run with an arcadevga and jpac. its in 15Khz mode right now, just wondering if going to 24Khz will work better in this set up while running mame games?
brendz
Re: jpac 24kHz
« Reply #1 on: November 15, 2007, 09:26:13 am »
anyone have any insite into this??
ahofle
    • Arcade Ambience Project
Re: jpac 24kHz
« Reply #2 on: November 15, 2007, 12:43:29 pm »
What games are you looking to play?  There are very few games that use medium resolutions (Paperboy comes to mind).  I'd stick with 15khz personally since probably over 90% of games used CGA resolutions.
brendz
Re: jpac 24kHz
« Reply #3 on: November 15, 2007, 05:41:49 pm »
mostly vert shooters and bubble bobble. i was just wondering if thru the magic of mame it would become a super better resolution somehow even if the orginal game is 15khz.
ahofle
Re: jpac 24kHz
« Reply #4 on: November 15, 2007, 05:51:09 pm »
Well, I actually do use medium resolution for a few vertical shooters (the ones with over 300 horizontal lines like DonPachi).  But if you mainly play those types of games, I would consider mounting your monitor vertically and run at 15khz for maximum authenticity.
brendz
Re: jpac 24kHz
« Reply #5 on: November 16, 2007, 04:31:55 pm »
its vert 15kHz now, just wondering if vert 24khz will make an improvement in any way as its an option
ahofle
Re: jpac 24kHz
« Reply #6 on: November 16, 2007, 05:05:06 pm »
You're not going to do any better than the exact resolution and orientation of the originals (15khz/vertical).  The only two vertical EGA games I can even think of are Toobin and APB.
