Author Topic: FCE Ultra going SUPER fast  (Read 1799 times)
dommer
  • Last login:February 20, 2016, 06:54:10 am
« on: November 10, 2007, 07:54:35 pm »
I'm using FCE Ultra in my cabinet, and it works great, with one small problem.  There is a key which I happen to have mapped to player 1's b button which causes the emulator to start running at light speed.  For example, in tecmo bowl, when you press this button, you run from the end zone to midfield in less than a second.  What is the purpose of this function, what is it called, and is there some way to disable it?  Thanks in advance!
-Dom
fjl
  • Pixels Rule!
Re: FCE Ultra going SUPER fast
« Reply #1 on: November 11, 2007, 02:47:50 am »
It's a speed up button and its purpose is to quickly go through and intro or load a game quicker.
And you disable it through the User Interface menu.
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
« Reply #2 on: November 11, 2007, 01:33:00 pm »
Sounds like the Patriots!  :cheers:
Half of the people you meet are below average.
dommer
« Reply #3 on: November 21, 2007, 11:27:20 pm »
I don't see anything in any of the menus about it.  Are you speaking of FCE Ultra in particular?  Can you point me to the correct setting?  I'm using .97, which has the escape to exit hack for use in mame cabs.
gonzo90017
« Reply #4 on: November 22, 2007, 12:27:00 am »
Try going to Config>Map Hotkeys... and disable it there.
