Author Topic: Button Sizing and Spacing.  (Read 3640 times)
stace
« on: November 01, 2007, 11:25:51 am »
Guys,
I'm trying to sort out my cp design and hope you can help?
I understand that a happ button requires a hole of 1 1/8"  is that correct?
What is the overal width of the button including the 'lip' ?
Stace  :)
4Aaron GE
  • Last login:July 22, 2013, 10:27:07 pm
Re: Button Sizing and Spacing.
« Reply #1 on: November 01, 2007, 11:56:09 am »
Most buttons are spaced 1.5" apart, centre to centre.
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« Reply #2 on: November 01, 2007, 01:19:30 pm »
This is correct.  I personally suggest a fostner bit.  For other hole related questions, don't forget about this thread about hole sizes.
-csa
vidmouse
  • Oop! Ack! Thppphbt!
    • Vidmouse's Arcade
« Reply #3 on: November 01, 2007, 02:02:47 pm »
I've also used a step bit... a little rougher going, but
it gave me a cleaner hole.
From what I've read, most people get away with
just using spade bits too.
I think I saw a set of forstner bits at Big Lots the other day for
$15 or so... don't know how good they are though.
  • Last login:September 20, 2026, 04:18:36 pm
« Reply #4 on: November 01, 2007, 02:31:26 pm »
I use forstner bits to drill out the holes and I space them 1-3/8" on center.
stace
« Reply #5 on: November 01, 2007, 02:48:50 pm »
Thanks Guys  :cheers:
« Reply #6 on: November 01, 2007, 04:17:35 pm »
I used a spade bit, its all I had  :dunno
NoOne=NBA=
« Reply #7 on: November 01, 2007, 06:55:04 pm »
Ditto here.
More important than the type of bit you use is making sure that you are not drilling the hole at an angle.
I don't know how many times I've seen a "defective button" that suddenly worked when you let up some pressure on the keeper nut.
Avrus
  • Last login:September 07, 2011, 09:17:25 pm
  • Canada
    • The Avrus Arcade Project 'Conquest'
« Reply #8 on: November 01, 2007, 08:15:03 pm »
I used a spade bit and the point on the spade bit allows you to line up the button exactly.
______________________________
'Conquest' upright 4 player arcade project log:
http://avrus.blogspot.com/
ArtsNFartsNCrafts
  • Last login:October 12, 2020, 09:22:50 pm
« Reply #9 on: November 16, 2007, 10:07:48 am »
I purchased my push buttons from ultimarc.  Anyone know the specs on these as far as proper spacing and spade-bit size for drilling?
Hoopz
  • Intellivision Rocks!
« Reply #10 on: November 16, 2007, 10:11:03 am »
ArtsNFartsNCrafts
« Reply #11 on: November 16, 2007, 10:13:48 am »
Ah, so it is the same.  Good deal.  Thanks!  :cheers:
