Author Topic: Adding hard drive to modded PS2 question  (Read 4569 times)
JMB
  • Last login:July 20, 2023, 07:29:22 pm
« on: October 19, 2007, 01:50:42 pm »
I have an old PS2 with a Messiah 2 Pro chip installed.  Since I have a bunch of old drives kicking around I figured I would pick up a network adapter and throw one in the PS2.  Are there any problems trying to use the drive with a mod chip installed?
Green Giant
Re: Adding hard drive to modded PS2 question
« Reply #1 on: October 19, 2007, 04:40:07 pm »
As long as it can support some form of OS that can play games, it will be fine.
I have the DMS4 in mine running Toxic OS.  Games load really fast and play great off the drive.
Toxic Arcade, my first build
SlammedNiss
  • Last login:Yesterday at 06:44:53 pm
  • Mine Drags the Ground!
« Reply #2 on: October 20, 2007, 02:01:10 pm »
google 'hdadvance' and that will lead you in the right direction. I have a Matrix Infinity and can boot hdadvance by pressing L1 when turning on the PS2. You may or may not be able to do that depending on the features of your modchip.
JMB
« Reply #3 on: October 22, 2007, 01:21:28 pm »
Thanks for the replies.  I have found some good info.
whatzcrackn
  • Last login:January 19, 2019, 12:14:02 pm
  • U just won tickets to da 'GUN SHOW'
« Reply #4 on: October 22, 2007, 02:05:02 pm »
does your ps2 have to have a modchip installed?
SithMaster
« Reply #5 on: October 22, 2007, 02:50:46 pm »
No you can get away with using a Swapmagic disk (3.6 i think) and burning a hdadvance disk.
Actually while im here i have a question.  Has anyone here used a HD with the slim ps2 after installing the hardware that lets you use an ide port?  I havent checked in a while and was just wondering how easy they are to install compared to a chip.  thanks.
« Last Edit: October 22, 2007, 02:53:27 pm by SithMaster »
whatzcrackn
« Reply #6 on: October 22, 2007, 06:08:39 pm »
So Swapmagic can not be a back-up?
SithMaster
« Reply #7 on: October 22, 2007, 06:23:10 pm »
Nope has to be the store bought disc.
I was just checking out the HD combo and HD connect and im really thinking of getting the former.  I cant solder very well but i have a friend that might be able to help me with that.  Has anyone here used the HD combo before or know someone who has?  Thanks.
« Last Edit: October 22, 2007, 06:29:32 pm by SithMaster »
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #8 on: November 07, 2007, 05:01:19 pm »
I just installed a HDconnect on my v12 slim. I believe the soldering will be identical for the HD combo - the main difference the combo comes with a replacement case for the slim...
If you are not happy with soldering, definately get some help. It's not as hard as a ps2 modchip as (at least with the HDconnect) you get ribbon cable that is shaped correctly to be soldered directly to the pcb.
I was surprised modding the ps2 slim - I've modded xbox, Gamecube, Wii, N64 etc... PS2 (slim) was far and away the hardest - lots of VERY small solder points. I assume a regular ps2 is easier but never opened one.
Also dissapointed to discover some HD's simply do not work - mainly WD it seems - completely not detected. Very fustrating.
