Author Topic: Roms work in ADVmame but not in mame win command line  (Read 1688 times)
CathalDublin
  • Last login:March 01, 2024, 04:05:23 pm
« on: October 16, 2007, 06:18:27 pm »
Any idea why roms work in Advancemame but in mame windows command line
it says missing roms?
Is there a quick way to fix convert all these roms?
almost half my roms are like this and ive 15gbs
there all zip files BTW
Defender(multiwilliams), SF2CE
Whirlwind, Lethal Weapon 3
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Roms work in ADVmame but not in mame win command line
« Reply #1 on: October 16, 2007, 07:35:24 pm »
Either mame doesn't refer to the correct rom folder, or your AdvanceMame and Mame are different versions.  BTW, AdvanceMame is not currently updated anymore.
If it's the former, edit the mame.ini file to point to the roms folder (to make mame.ini, type mame -cc).
If it's the latter, clr mame pro.
Robin
Knowledge is Power
CathalDublin
« Reply #2 on: October 17, 2007, 05:47:53 pm »
Thats the point I dont use advancemame anymore
Was using as I was using Lincade
But decieded to give Windows a try and am now using MAME command line viewer with mamewah, but half the romsseem to be incomplete even though they worked in Advancemame and they were downloaded in a set made for mame 119
Ah it grand re-downloading the latest romset 120 I think it is 16gb  :banghead: 2days-3Days torrent on my connection :(
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: October 17, 2007, 07:43:04 pm »
If they worked with mame 0.119, far more than a half should be still working with 0.120.  I'd guess 98% should still work (without any testing).
Have you run CMPro on the set & mame 0.120?  Or did you run cmpro on the old version of advancemame, and not rerun it on the current mame?
Or you could use mame 0.119 if that's the sets you have.
Robin
Knowledge is Power
