Author Topic: LCD PC Monitor vs LCD HTDV  (Read 2529 times)
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
« on: October 07, 2007, 09:12:17 am »
I am building a slim LCD cabinet and am considering either an LCD PC Monitor or an LCD HDTV.
Size selection aside, is there any difference for MAME purposes as long as the TV has a VGA input?
« Last Edit: October 07, 2007, 09:42:01 am by Santoro »
Neverending Project
    • Arcade Fixer
Re: LCD PC Monitor vs LCD HTDV
« Reply #1 on: October 08, 2007, 12:30:07 am »
If it is an LCD HDTV, it will most likely have HDMI or DVI input. Some also have VGA, but from what I recall it is less common. Also, some computers/video cards have a tougher time communicating with an LCD TV through HDMI or DVI.
Other than that, an HDTV will have some thing that a monitor will not: Remote, built-in speakers (which will make the overall size larger). But a monitor may have useful things too, like USB hubs. It all comes down to what you find.
And finally, you will almost only find an HDTV in a widescreen aspect ratio (16:9). But depending on the size, you may still find an LCD monitor in 4:3, which may be more desirable for a cabinet.
rdenis
  • Last login:January 11, 2011, 04:19:38 pm
« Reply #2 on: October 08, 2007, 02:27:57 am »
Assuming widescreen:
LCD Monitor (WS) is 16:10
LCD HDTV (WS) is 16:9
How much of a difference is this?  If you compare a 27.5" viewable area for each, the dimensions are as follows:
16:9 is 23.97" x 13.48"
16:10 is 23.32" x 14.57"
That's over a one inch difference on vertical which is relevant if you are not going to rotate your screen.
I'm going throught the exact same decision process right now.  I would definitely go for the monitor over HDTV when LCD is the choice.
TOK
  • Last login:Today at 07:06:25 am
  • The Game Always Wins
« Reply #3 on: October 08, 2007, 08:58:07 am »
Aren't LCD PC monitors higher resolution? I don't have an LCD TV, but the ones I have seen couldn't display small text as clearly as a PC monitor. They're mostly designed for 10 foot+ viewing distances.
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #4 on: October 08, 2007, 11:21:43 am »
I use my hdtv as my main monitor (dvi -> hdmi) and I have it set to 1920x1080 resolution, plenty big enough ;D. Most of them are designed for 720p/1080i resolutions which is more than enough really. Of course in a cab you aren't going to want gigantic resolutions anyway so that's not a problem.
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #5 on: October 11, 2007, 09:26:25 pm »
I wound up buying a 20' LCD.  The price was very good....
Thanks to all for the feedback.
