Author Topic: Control Panel Wire Holder and Strain Relief  (Read 2247 times)
fjl
  • Pixels Rule!
« on: October 07, 2007, 02:40:36 am »
What can I use to hold the wire coming out of my control panel? Basically I want something similar to like whats on a controller. It's usually made of rubber or plastic and covers the wire going into the controller and at the plug. It's also somewhat flexible to prevent the wire from being bent too much and breaking. A bend relief boot or strain relief boot. I believe thats what they are called. Where can I get one of these to fit my wooden control panel?
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 12:32:14 am
Re: Control Panel Wire Holder and Strain Relief
« Reply #1 on: October 07, 2007, 04:35:49 am »
I know what you mean, and I think that your description is right  - but I usually see these rubber boots designed for plastic or metal containers.  Maybe you will need to cover a hole with a small metal plate?  I've seen metal-mesh used before for this.
I'm sure that you can buy a boot from your local electronics store, or even online.  But don't try a shoe store ;)
fjl
  • Pixels Rule!
« Reply #2 on: October 07, 2007, 12:06:27 pm »
I was thinking of putting some metal and a rubber grommet but that doesn't work as a strain relief. That only keeps the wire from being damaged by the sharp edges. I need something that will work as a grommet, hold the wire in place from being pulled out and as a strain relief.
What have you guys that have been making stand alone control panels been using?
mountain
  • Trade Count: (+9)
  • Last login:March 06, 2026, 07:42:38 am
    • Mountain Jukeboxes
« Reply #3 on: October 07, 2007, 12:43:26 pm »
Mouser.com has them. Use Mousers search tool and search for part number 836-1364.
fjl
  • Pixels Rule!
« Reply #4 on: October 07, 2007, 01:09:25 pm »
Thats cool thanks. But I was also hoping they would have a strain relief boot/sleeve. Do you know of any of those? Maybe I'll just try one of these out.
But if anyone knows of any please give your insight and links.
  • Last login:April 19, 2026, 07:24:05 pm
knave
  • Last login:March 24, 2026, 03:52:12 pm
« Reply #6 on: October 08, 2007, 11:45:18 am »
I have used heat shrink tubing and have gotten good results.  Sometimes I've used multiple sizes on top of each other to get the desired flex limitation.
