Author Topic: Should I go with a 25 or 33" arcade monitor?  (Read 2376 times)
Jm1010
  • Last login:November 17, 2008, 08:16:22 pm
« on: September 03, 2007, 09:31:26 pm »
Hi everyone, I am new to this and hope not to make too many mistakes building my first mame.
My part guy is offering me both a 25" or 33" arcade monitor for the same price ($150).
The cabinet is an ultimate arcade II.
Should I go for the larger monitor? Would the 33" look too big in such a cabinet? Be too much " in your face";  Is the resolution typically worse on these monster monitors? What else should I consider before I decide?
Thanks for your help!!!
JM
jmdb@rogers.com
« Last Edit: September 03, 2007, 10:20:36 pm by Jm1010 »
telengard
  • Last login:April 28, 2026, 11:37:11 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
Re: Should I go with a 25 or 33" arcade monitor?
« Reply #1 on: September 03, 2007, 10:42:52 pm »
I find the bigger the monitor the harder it is to play games.  Seems when the monitor is large you actually have to move your head.  I have a 19" in my cab for that reason.  The 25" MsPac/Galaga reunions are real tough for me to play.  If your choice is between 25" & 33" I personally would go for the 25.
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
TOK
  • The Game Always Wins
« Reply #2 on: September 04, 2007, 07:06:24 am »
It sounds like the 33 would be too large based on your distance from the cabinet.
Here is a trick I found that works for me... Stand at the control panel in the playing stance. Reach your right arm straight out. If any finger touches the bezel, more than a 27" monitor is going to be uncomfortable.
I have a 27" mounted vertically in a regular stand up cab, and it's just on the comfort threshold.
ahofle
    • Arcade Ambience Project
« Reply #3 on: September 04, 2007, 12:37:29 pm »
Definitely 25" for your UAII.  I would only use 33" for a showcase cabinet.  Also, the scanlines on larger monitors at CGA resolutions are much bigger.
Angry_Radish
  • Last login:October 24, 2020, 06:36:17 pm
« Reply #4 on: September 04, 2007, 04:42:43 pm »
Take them both, and build a showcase too!
Seriously though, 25" is the max you would want in a UAII cab.
Jm1010
« Reply #5 on: September 04, 2007, 10:22:47 pm »
Thanks a lot guys, I'll stick with the 25" option; it will be better for my eyes and save some lumber too!
JM
