Author Topic: Can't get my monitor out of "Power Save Mode" - DVI RUINS DELL LCDs  (Read 4202 times)
  • Last login:June 10, 2026, 01:52:21 pm
This is weird... I had my MAME computer set up on the dining room table to get everything configured properly.  We were having company so I unplugged everything and moved it to the basement.  When I fire up the computer now the monitor (a standard Dell LCD connected via DVI/VGA adapter) doesn't display anything other than "move mouse or hit any button on keyboard to get out of power save mode."  Obviously, doing this doesn't work.
I had the computer set to boot straight to MaLa and I am using a video card with DVI out (hence the DVI/VGA converter).  Everything was working properly upstairs (including several reboots) but now it isn't.
Any thoughts?
« Last Edit: August 28, 2007, 10:42:43 pm by javeryh »
SirPeale
  • Green Mountain Man
Re: Can't get my monitor out of "Power Save Mode"
« Reply #1 on: August 28, 2007, 10:23:01 am »
Try the monitor on another computer.  If you still have issues, you have a monitor problem.
ARTIFACT
« Reply #2 on: August 28, 2007, 10:49:07 am »
actually
he exact same thing happened to my wifes computer
and it was actually that her video card was FRIED.
she also has a dell screen
the way this ''power saving mode'' is named is misleading
try to swap the video card and see
« Reply #3 on: August 28, 2007, 09:10:50 pm »
Thanks guys... I'll give it a try on my other computer and then remove the video card.  The computer and monitor are all brand new (including the video card) so I'll be disappointed if something is wrong.  It was working perfectly before I brought it downstairs.
« Reply #4 on: August 28, 2007, 10:42:10 pm »
OK, after looking into this further it is a monitor problem.  Apparently when you hook up a Dell LCD to to a video card with DVI it borks the monitor.  I can't believe this - I paid $200 for this monitor and just hooking it up to a DVI connection ruins it - no warning or anything.  I don't know what to do other than complain to Dell but they can't seem to even find my order in their system.
SirPeale
Re: Can't get my monitor out of "Power Save Mode" - DVI RUINS DELL LCDs
« Reply #5 on: August 29, 2007, 01:42:14 am »
Does the monitor have a DVI connector, or did you use some kind of adaptor?
« Reply #6 on: August 29, 2007, 09:58:01 am »
I used an adapter.  I took out my video card and reinstalled it and now it seems to be working.  What's weird is that it wasn't working at all with my laptop.  It would say something like "no signal" when the monitor was powered on (green light) but as soon as I'd plug the VGA cable in it would go into power save mode (amber light).  I guess I'll just hope it continues to work once I get it installed in my cabinet... it's all I can really do I guess.  I can't believe what a widespread problem it is for Dell.
