Author Topic: samsung 27 hdtv 4.3  (Read 2467 times)
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
samsung 27 hdtv 4.3
« on: August 22, 2007, 07:18:09 pm »
i recently had a presentation monitor it died on me can i use this type of tv for a mame monitor it does 480p 480 i don't want any flicker the screen is 4.3 instead of 16 .9
ahofle
    • Arcade Ambience Project
Re: samsung 27 hdtv 4.3
« Reply #1 on: August 23, 2007, 12:22:41 pm »
What type of connectors does it have?  I believe you will be limited to 480i (ie. flicker) if you go the DVI to component dongle route.
alienware32
« Reply #2 on: August 23, 2007, 02:52:30 pm »
i have a radeon x1300 with componet out the card can do 480 i 480 p 720 p 1080 i
« Last Edit: August 23, 2007, 03:38:06 pm by alienware32 »
alienware32
« Reply #3 on: August 23, 2007, 02:53:13 pm »
the tv has hdmi and componet out
ahofle
« Reply #4 on: August 23, 2007, 05:50:22 pm »
How was the presentation monitor connected?  RGB?  If so, I think you will be disappointed going from CGA/RGB to component.  Also I'm not sure what benefit the high def signals will give you seeing as how most arcade games are CGA resolution.  I imagine it will be similar to running the games on a PC monitor.
alienware32
« Reply #5 on: August 23, 2007, 06:00:15 pm »
the presintation was hook up using a radeon 8500 soft 15  the tv is a crt tv flat screen i miss the presintation monitor i just dont want any flicker and a arcade monitor is expensive to ship
