Author Topic: Mounting a CRT in a mini cab  (Read 1682 times)
ratzz
« on: August 21, 2007, 05:53:36 pm »
Hi all,
I'm building a mini galaga / pacman cab and wondered if anyone had succeeded in installing a CRT of any size in one.
I know it will be wide enough but will it be deep enough taking into account the unique angle of the monitor - I.e. will I struggling to get the back on?
Any advice would be great.
Ratzz  :cheers:
  • Last login:Today at 04:27:34 pm
Re: Mounting a CRT in a mini cab
« Reply #1 on: August 21, 2007, 06:38:50 pm »
ok - so I have a bit of experience with this. I just completed a mini galaga style cabinet (http://forum.arcadecontrols.com/index.php?topic=68683.0). Here is a pic:
As you can see, the monitor mounts straight up. This cabinet is true to scale in the fact that the bezel is properly sized and was reduced to 25% of it's normal size, same with the sideart and marquee.
Before I built the mini bartop cabinet, I had considered a mini cabinet that had proper proportions. I made a mockup with cardboard. Here is a pic:
After I built it, I could see the monitor would not really be visible, and thus the game would be more for looks than playable.
The monitor is a 10"/9" viewable CRT monitor. So I went with the more playable but not 100% accurate bartop. Your call! What size monitor you talking about using?
« Last Edit: August 21, 2007, 06:40:43 pm by leapinlew »
  • Last login:Today at 11:57:54 am
« Reply #2 on: August 21, 2007, 06:40:45 pm »
It is not possible to scale a Ms. Pac-man/Galaga cabinet down to 75-80% and fit a 19" CRT in there properly.  I looked into it when I was building mine and it wasn't even close.  I didn't want to put a tiny 14" or 15" one in there so I didn't look into that and decided to go with a 19" LCD which fit quite nicely.  You might have better luck with a smaller monitor...
ahofle
    • Arcade Ambience Project
« Reply #3 on: August 21, 2007, 06:42:12 pm »
Wow, that is simply AWESOME.   :applaud:
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: August 21, 2007, 06:53:36 pm »
Isn't 75% of 19" less smaller than 15" ?
Working: Not Enough
Projects: Too Many
Progress: None
« Reply #5 on: August 21, 2007, 07:02:18 pm »
yeah... my math skills aren't what they used to be.  ;)
Something looked "off" when I scaled down the size of the monitor during the design phase.  I'm not sure why since the ratio was the same all the way around.  Because of this, I decided to scale down everything except for the size of the monitor.  Now I have a min cab with a monitor that looks pretty big comparatively and since bigger = better, I win!    :cheers:
ratzz
« Reply #6 on: August 22, 2007, 06:22:08 am »
Thanks for that guys. Thought that might be the answer, but was hoping!
And I know your thread well leapinlew -- great little cab!
