Author Topic: JPAC not showing red....  (Read 2032 times)
gibbous
  • Last login:September 02, 2013, 12:43:17 pm
« on: August 12, 2007, 05:25:13 pm »
I just tried hooking up my JPAC to a couple of arcade cabinets.  Both these cabinets normally show all colors perfectly when hooked up to their respective game PCBs (one is a Megalo 410 running MVS, the other is a Dynamo 25" running SFA3), but using Soft15khz and the JPAC, I'm not getting any red coming through.  I tested pin 12 on the parts side, and I do get 4.97V coming through there.  Is there something I'm missing or do I have a bad JPAC?
Thanks.
SirPeale
  • Green Mountain Man
Re: JPAC not showing red....
« Reply #1 on: August 12, 2007, 08:39:18 pm »
You very well could, esp if you're hooking up a board and getting red, then hooking up the J-PAC and losing it.
gibbous
« Reply #2 on: August 12, 2007, 11:02:19 pm »
Yup, that's exactly what's happening.
But actually, I'm not getting 5v off the red, I got the wrong pin.  I went 12 in from the 28 pin.  It's 2.1V off the real red pin.  Not sure what's "normal" there, but I e-mailed that info to Andy to see if he could help.
Pretty frustrating.  Finally found some time to work on it and it doesn't quite work.    :banghead:
gibbous
« Reply #3 on: September 01, 2007, 10:36:01 am »
BTW - as you might expect, Andy sent me a new J-Pac.  Works great now.   ;D
