Author Topic: Using Arcade monitor for other emulators?  (Read 2589 times)
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« on: August 01, 2007, 05:04:28 pm »
I understand how to hook up my CGA monitor now to the PC and understand mame supports arcade monitor resolutions. However does Fusion(32x, SCD, genesis) emulator be able to run on this display? SNES emulator etc.
ahofle
    • Arcade Ambience Project
Re: Using Arcade monitor for other emulators?
« Reply #1 on: August 01, 2007, 06:31:48 pm »
Any arcade monitor can run at 640x480 interlaced.  So you as long as your emulator supports 640x480 at a minimum (most do), you are fine.  I've run just about every emulator successfully on an arcade monitor (they look gorgeous BTW) including NES, SNES, atari2600, N64, Sega, etc.
mrserv0n
« Reply #2 on: August 01, 2007, 07:17:35 pm »
SWeet!! Thanks cant wait!!  ;D
StephenH
« Reply #3 on: August 01, 2007, 07:26:09 pm »
You may also be able to run them at their lower resolutions non-interlaced.
mrserv0n
« Reply #4 on: August 01, 2007, 08:25:00 pm »
Which is clearer, non-interlaced right?
northerngames
  • Trade Count: (+18)
« Reply #5 on: August 10, 2007, 11:34:24 am »
right non-interlaced is better
