Author Topic: Flippin' SG...  (Read 2681 times)
crashwg
Flippin' SG...
« on: July 25, 2007, 10:19:49 pm »
So my friend Chad is left handed.  Apparently nobody at redoctane is though since they still have not released a left handed SG.
I had a spare so I sold it to Chad.  He went out and bought some epoxy and bondo and we got to work.
First we formulated our plan of attack.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
crashwg
Re: Flippin' SG...
« Reply #1 on: July 25, 2007, 10:22:11 pm »
When we thought it looked good we cut the whammy bar support out.
« Last Edit: July 25, 2007, 11:05:30 pm by crashwg »
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #2 on: July 25, 2007, 10:26:53 pm »
This is the part that holds the tilt sensor.  We could have fitted it in the flipped SG in some custom way but figured it'd be easier to reuse the existing mount so we cut it out.
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #3 on: July 25, 2007, 10:33:10 pm »
Here is the new position of the whammy bar.  It's not exactly symmetrically placed compared to the original position but we had to stay away from the part of the guitar body that slants off.
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #4 on: July 25, 2007, 10:42:58 pm »
In this picture you can see to the left of the guitar, the piece that holds the tilt sensor and the two other pieces of original guitar that came from the place where the whammy bar was relocated to.  Also, you can see the whammy bar's support has been epoxied in it's new location.  The white you see is a piece of a computer monitor stand that I had lying around as scrap.  It goes over both the guitar body and the relocated piece to act as support.  It along with the SG are both ABS plastic so I figured if the epoxy stuck to the one it would stick to the other.  It is only on three sides because when we cut out the whammy bar support we had to stay away from the start/select buttons and therefor didn't have a place to glue the support piece to.
« Last Edit: July 25, 2007, 10:45:42 pm by crashwg »
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #5 on: July 25, 2007, 10:47:33 pm »
Here you can see where we used more scrap ABS as backing and epoxied the crap out of everything.
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #6 on: July 25, 2007, 10:51:49 pm »
Kinda slipped the mind that when we started bondoing something would need to back all the holes, especially the two we created by cutting out the tilt sensor support.  Unfortunately, we were out of epoxy and ABS so we substituted a CD case and SuperGlue...  So far it seems to be holding.
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #7 on: July 25, 2007, 10:53:19 pm »
Yay Bondo!
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #8 on: July 25, 2007, 10:57:07 pm »
Had to move the strap peg.  Unlike the original position which was between the two halves both with 1/2 a hole we just drilled a hole in the back half and superglued it in place.
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #9 on: July 25, 2007, 11:03:32 pm »
Sanding of bondo has been done.  Here's the first fit test.  The wires to the tilt sensor weren't quite long enough so it is not where it should be but everything else went together smoothly.
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #10 on: July 25, 2007, 11:03:58 pm »
This space reserved for future updates!
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #11 on: July 25, 2007, 11:04:13 pm »
Same here.
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #12 on: July 25, 2007, 11:04:28 pm »
Ditto.
Lemme say it again
crashwg
Re: Flippin' SG...
« Reply #13 on: July 25, 2007, 11:04:50 pm »
Alright, this should be enough.  8)
Lemme say it again
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
Re: Flippin' SG...
« Reply #14 on: July 26, 2007, 12:14:06 pm »
I'm a lefty. I just assumed that meant I'd never play GH so I try to ignore the threads on it. Maybe there's hope.  :P
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
Re: Flippin' SG...
« Reply #15 on: July 26, 2007, 12:45:48 pm »
Will the game let you flip the display so that your friend doesn't have to reverse the direction of the fret buttons as well?
If no one feeds the trolls, we're just going to keep eating your goats.
AtomSmasher
    • Atomic-Train
Re: Flippin' SG...
« Reply #16 on: July 26, 2007, 12:55:35 pm »
Yes.
