Author Topic: QNIC CGM2500 INFO NEEDED  (Read 2307 times)
FrizzleFried
    • Idaho Garagecade
« on: July 15, 2007, 08:00:36 pm »
I just picked up a QNIC CGM2500 25" monitor locally for $30.00.  It is not working.  The guy I bought it from can only say it didn' t work when he got the cabinet (Neo-Geo).  I plan on doing a CAP KIT first.  Does anyone have ANY INFO on this monitor?  I found a schematic,  but that is just about it.
Ken Layton
  • Guru
  • Technician
Re: QNIC CGM2500 INFO NEEDED
« Reply #1 on: July 16, 2007, 01:56:27 am »
I've only heard of that monitor. Never encountered one myself.
You want capkit # 605 from Zanen Electronics.
FrizzleFried
    • Idaho Garagecade
« Reply #2 on: July 16, 2007, 12:02:53 pm »
Zanen doesn't sell the flyback ...any idea where I can get one?
He mentioned that he has seen a number of these with bad flybacks.
I'll bust out the cap kit first,  but then go from there.  I do have to say there seems to be a LOT of "oily" substance around the flyback area...whatever that is?!
Ken Layton
  • Guru
  • Technician
« Reply #3 on: July 16, 2007, 06:10:37 pm »
For flybacks try here:
http://www.hrdiemen.es/products/index.php?command=viewPage&page=homesite&language=eng-GB
Type the numbers off of the flyback itself or the manufacturer's part numbers from the monitor service manual into the search box.
Also try www.mcminone.com as they distribute not only the HR Diemen line of replacement flybacks, they also carry OEM flybacks under their original makers part numbers.
The oily splooge you see on the circuit board is from a pinhole leak in the flyback.
FrizzleFried
    • Idaho Garagecade
« Reply #4 on: July 16, 2007, 07:00:49 pm »
Thank you!
Would you then recommend I replace the flyback immediately or install a capkit then attempt to run the monitor first?  The only know history of this monitor is that it worked then it didn't.  Not a whole lot to go on.
Ken Layton
  • Guru
  • Technician
« Reply #5 on: July 16, 2007, 11:58:59 pm »
If the flyback looks physically ok then I'd do a capkit first then try powering it up. It's also very likely that oily goo is from a capacitor splooging it's guts out.
