Author Topic: Mamewah trouble!  (Read 2008 times)
Nightmare03
  • Last login:August 18, 2007, 07:20:34 am
  • Stupid llama!
Mamewah trouble!
« on: July 14, 2007, 09:24:47 am »
Hey,
Im running mamewah version "1.62b13" and i can't get any layouts to work nor can i setup any additional emulators  :dunno
I've googled and googled but none of the information makes sense, this mamewah seems alot different? I added the entry "layout" to mamewah.ini, loaded up mamewah and it used the default layout and removed my entry from the ini  :angry:
Someone... anyone... help!
I've also attached my snes.ini file, if someone could check it out and tell me where im going wrong i would appreciate it!
Thanks.
« Last Edit: July 14, 2007, 09:28:44 am by Nightmare03 »
mcfreak
  • Last login:March 01, 2021, 01:55:04 pm
  • Asteroids moving along...
    • Hobby Blog
Re: Mamewah trouble!
« Reply #1 on: July 14, 2007, 09:43:45 am »
Try using "auto:rom_folder" instead of rom_folder.
I also ended up just renaming the layout I wanted to the default name and then loading it into the layout editor, picking the backgroud and saving.
« Last Edit: July 14, 2007, 09:48:53 am by mcfreak »
Nightmare03
  • Stupid llama!
« Reply #2 on: July 14, 2007, 10:01:13 am »
Bah!!!
This is sending me insane! I did what you did with the background (thanks for the tip), background appeard fine in the layout editor but not in the main app?!
Also, its not listing any roms  :banghead:
mcfreak
    • Hobby Blog
« Reply #3 on: July 14, 2007, 10:08:11 am »
does the MAME list work?
Also, is the layout.lay file you want in the root of /config?
Nightmare03
  • Stupid llama!
« Reply #4 on: July 14, 2007, 10:14:41 am »
Mame works fine.
layout.lay and background.jpg are both in /config
mcfreak
    • Hobby Blog
« Reply #5 on: July 14, 2007, 12:25:00 pm »
once you set auto:rom_folder did you go back and generate the list?  I am blindly guessing now...
Nightmare03
  • Stupid llama!
« Reply #6 on: July 14, 2007, 01:58:05 pm »
Yep i did that, nothing shows up  :dunno
Nightmare03
  • Stupid llama!
« Reply #7 on: July 15, 2007, 11:05:39 am »
Bump  ;D
« Reply #8 on: July 19, 2007, 10:15:54 am »
Grab v1.62b13a from the Mamewah board @ Mameworld - I only recently noticed that I never got round to updating my website with that version.
Nightmare03
  • Stupid llama!
« Reply #9 on: July 19, 2007, 01:49:49 pm »
It works!  ;D
Thanks a bunch minwah!
