Author Topic: monitor for mame question  (Read 2426 times)
squizz
  • Last login:May 20, 2005, 05:32:41 am
« on: April 21, 2003, 09:17:35 am »
 Hello
  i'm about to build a mame cabinet which i would like to  install an arcade monitor into it.
  so the question is this.
  after installing an arcadevga card , what monitor will be the best bet to go with, atm the cabinet will be an x turtle cab, which has a blown 26in installed , so i would like to get another 26in monitor.
  so now over to you experts  ;)
paigeoliver
  • Awesome face!
Re:monitor for mame question
« Reply #1 on: April 22, 2003, 01:07:46 am »
What is "blown" in the monitor it has now? Most monitors are fixable. I wouldn't just give up on a monitor that size without at least trying to fix it.
android
  • Last login:August 21, 2006, 09:44:47 am
« Reply #2 on: April 22, 2003, 10:12:10 am »
You should get a standard resolution arcade monitor.
squizz
« Reply #3 on: April 26, 2003, 03:41:46 am »
  The tube is caputt :)
  and too many other things to fix on the board.
 was seen by an arcade tech and was told to throw it away.
squizz
« Reply #4 on: April 26, 2003, 03:43:41 am »
 And how does the arcadevga look running pacman and pengo etc games.
  can you get them to fill the top and bottom of a horizontal screen ?
 thanks
paigeoliver
  • Awesome face!
« Reply #5 on: April 28, 2003, 05:10:06 am »
I have often wondered about vertical games displayed horizontally on an arcade monitor. They have simply got to be losing some resolution.
