Author Topic: Average FPS on exitting mame  (Read 993 times)
DarkDraco
  • Last login:June 30, 2016, 03:42:53 pm
« on: June 02, 2007, 11:48:48 am »
How do you disable this? i looked all over the play for a command line or something to get rid of this. its really irritating me. plz help thx
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Average FPS on exitting mame
« Reply #1 on: June 05, 2007, 09:40:38 am »
Most everyone is using a front end that hides the command window so that you never see that.  Only way I know to get rid of it would be to comment out the following line of code in video.c of the mame source files and recompile:
mame_printf_info("Average speed: %.2f%% (%d seconds)\n", 100 * final_emu_time / final_real_time, add_subseconds_to_mame_time(global.overall_emutime, MAX_SUBSECONDS / 2).seconds);
tikbalang
  • Last login:May 07, 2013, 05:04:54 pm
    • MAME BootCD's for DOS
« Reply #2 on: June 05, 2007, 10:03:44 am »
add "CLS" to your batch file, after the mame line. or, if your FE supports it, you can put "CLS" as the "post_command" (which will be run after mame). gamelauncher has it.
good luck.
