Author Topic: Cpviewer help  (Read 1758 times)
gonzo90017
Cpviewer help
« on: May 28, 2007, 03:11:19 am »
Can cpv2 exit using usb gamepads?  I set up button 3 to launch cpv2 and it works but when I press it again to exit, it wont. I tried every button but nothing. It only exits when I press a keyboard button. Since my projecI won't be using a keyboard, only gamepads, that's my problem.
Dmod
  • Last login:July 12, 2012, 06:50:45 pm
Re: Cpviewer help
« Reply #1 on: May 28, 2007, 01:01:24 pm »
For what it's worth, I have exactly the same problem and posed the same question on the Main board yesterday.
I also tried Johnny5 but it seems to only detect keyboard presses as well.
::edit::
After searching the boards, it seems like AutoHotKey can be used to convert the joystick buttons into keypresses.  I'm going to play around with this a bit but I think you can write a batch file that calls CPViewer and AHK.  AHK can convert the button press to close CPViewer and then exit.
« Last Edit: May 28, 2007, 10:22:50 pm by Dmod »
My Projects:
Suspended Animation Scratch-built Cab
Driveshaft Arcade Seat Platform
Dmod
Re: Cpviewer help
« Reply #2 on: May 29, 2007, 02:54:20 am »
I got this working.  In my setup I'm using MaLa to launch CPV2 and needed a way to close it.  I created a 2-line batch file which MaLa calls as "mycpv2.bat -r=%parent%".  The batch file looks like this:
mycpv2.bat:
start test.ahk
cpv2 %1=%2
Test.ahk is an AHK script file that waits for my P2 start button to be pressed (I'm using Joystick 2 Button 7).  Once pressed, the script checks to see if CPV2 is the active window.  If so, it sends a keypress (I used "_") to CPV2 and loops to make sure CPV2 closes.  Once closed, the script kills itself.
Here's my AHK script.  The part labelled "2Joy7::" is the relevant part.  The other part labelled "`::" just allowed me to find out the title of the CPV2 window and is not necessary.
I tested this out a lot with MaLa tonight and it appears to be stable.
Hope this helps.
-D
test.ahk:
; AutoHotkey Version: 1.x
; Language:       English
; Platform:       Win9x/NT
; Author:         A.N.Other <myemail@nowhere.com>
; Script Function:
;   Template script (you can customize this template by editing "ShellNew\Template.ahk" in your Windows folder)
#NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases.
SendMode Input ; Recommended for new scripts due to its superior speed and reliability.
2Joy7::
WinGetActiveTitle, Title
if (Title = "CPV2 Viewer") {
  Loop, 100 {
    Send _
    if (Title <> "CPV2 Viewer") {
      ExitApp
Return
Run Notepad
WinWait Untitled - Notepad
WinActivate
Send %Title%
Return
« Last Edit: May 29, 2007, 03:13:32 am by Dmod »
My Projects:
gonzo90017
Re: Cpviewer help
« Reply #3 on: May 29, 2007, 03:22:30 pm »
Thank's i'll try it tonight.
