Author Topic: Arcade monitor and pc issues  (Read 3456 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: May 14, 2007, 03:19:41 pm »
Hi guys im converting an old Golden Tee 2005 into a mame cabinet. I got my arcade vga card today installed the drivers and got the boot up screen to appear on my arcade monitor but now I can still hear the golden tee playing in the background and the screen doesnt fit the monitor and it looks all shakey. I have been trying different things but it doesnt seem to alter the screen.
My monitor is this
Marky_1979
    • Personal Webspace
Re: Arcade monitor and pc issues
« Reply #1 on: May 14, 2007, 03:23:36 pm »
Image of screen image doesnt real capture the shakey effect think that might be a resolution/ refresh rate issue
grantspain
  • Last login:September 29, 2026, 03:33:53 pm
« Reply #2 on: May 14, 2007, 03:37:57 pm »
and you have tried all the adjustments on the remote board?
Marky_1979
    • Personal Webspace
« Reply #3 on: May 14, 2007, 04:01:48 pm »
Hi mate iv been looking for some switches but can only find some twisty nobs that alter brightness what do the switches look like and where would I locate them mate?
northerngames
  • Trade Count: (+18)
« Reply #4 on: May 14, 2007, 04:03:16 pm »
what res do you have the desk top set at?
is the monitor hooked to the pc only or both pc and golden tee since you hear it playing I assume everything is hooked up but the monitor is now on the pc instead?
AndyWarne
    • Ultimarc
« Reply #5 on: May 14, 2007, 04:30:22 pm »
The problem might be that the monitor has a jumper to select 15 or 25 Khz and it is set to 25. Should be set to 15.
Andy
Marky_1979
    • Personal Webspace
« Reply #6 on: May 14, 2007, 04:32:00 pm »
Hi Andy, where would I find this jumper? sorry this is all very new to me.
grantspain
« Reply #7 on: May 14, 2007, 04:53:58 pm »
andy is correct,BUT normally polo 2 are auto ranging between 15 and 25k(depends on the age),if you look on the chassis below the neck card it will tell you whether is auto or not(on the metal casing),btw the adjustment board is directly below the neck card
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #8 on: May 14, 2007, 08:00:35 pm »
Based on the picture, it is at the right resolution.
You need to find Vert hold, pincushion and width controls as well as brightness.
Or alternatively, what does your connection to the monitor look like?? I am asking this because your picture shows the vertical to be locked in half way up, or is it rolling.
Rick Nieman
Rick@niemandisplays.com
www,niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Marky_1979
    • Personal Webspace
« Reply #9 on: May 15, 2007, 03:22:54 am »
I found that mark mate it states its a 15/25 auto. I also found the controls and stretched the picture. I need to find the right resolution for the monitor and mamewah plus emulators etc.... not sure what is best 800x 600 doesnt seem to work nor does 640 x 480 and will I need to alter the screen refresh rate? cheers for all your help guys.
ahofle
    • Arcade Ambience Project
« Reply #10 on: May 15, 2007, 12:22:53 pm »
Have you tried adjusting VHold yet as Rick suggested?  640x480 interlaced should work assuming you didn't install the 'multisync patch' from Ultimarc.  You'll also need to be more specific than "640x480 doesn't work".
northerngames
« Reply #11 on: May 15, 2007, 07:59:24 pm »
I use a  nanao with a video amp mamewah set to 640X480 and same with windows if you go to the ultimarc site it explains how to use and hook the arcadevga up correctly also make sure your monitor wires are where they should be and not have your H or V on the green red or blue ground etc.
on my set-up it does not like 800X600 and when switched from 800x600 to 640x480 the monitor needs to be retuned otherwise it you could not make any display out becuase it is moving shaking rolling etc.
Marky_1979
    • Personal Webspace
« Reply #12 on: May 15, 2007, 09:10:00 pm »
Thanks guy think iv cracked it found the control panel it was in a strange place no where near the monitor. Iv also alter the screen settings went with 640 x 288 and it seems to work good apart from my NES emulator doesnt work now but think I might need to re configure it plus all my other emulators now.
