Author Topic: TV out issues  (Read 1452 times)
MattMaan
  • Last login:May 13, 2003, 06:39:22 pm
  • I wouldn't miss it for the world, Trebek!
TV out issues
« on: April 16, 2003, 03:49:48 am »
I've been tooling all over the web and haven't been able to find a solution to this, so maybe someone here has come across a similar problem.
I'm trying to set up TV-out in dos, running a voodoo3 3000.  I know the voodoos aren't the best cards for TV out, not to mention a massive pain to run in dos, but the price was right... ($0.00).  So the obvious solution of "buy an ATI" is out for now at least.
I can get the card to output in dos if I boot into win98 first, and then exit to dos, but not on a boot straight into dos.  Whats the trick?
-Matt
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
Re:TV out issues
« Reply #1 on: April 17, 2003, 12:16:17 am »
do you have a monitor hooked up also? are you using s-video or composite
I had/have the same card(using composite) and a tv acts just like a regular monitor when it's the only thing hooked up, i.e. it shows the bios screens, loading windows, using a boot floppy, setup from cd in 98,2000,xp. I seem to recall that it was a bit flaky when i had a monitor and tv at the same time, but that was a while ago so I dont recall
MattMaan
Re:TV out issues
« Reply #2 on: April 17, 2003, 11:33:37 am »
I'm running composite, at least on the TV I've been testing on (which wont be in the cabinet).  The output to the monitor is pretty crumby while TV-out is enabled, but the television is fine.  I haven't tried booting without any monitor attatched, just the TV... I'll give that one a try.
--Matt
MattMaan
Re:TV out issues
« Reply #3 on: April 17, 2003, 01:07:54 pm »
 :o  :o :o
Well, that did it... now I feel sheepish.  :-[  I've been working on that for the last 3 days....!  :P
Thanks very much!
-MAtt
