Author Topic: Visualboy Advance SDL rom naming question  (Read 1267 times)
gonzo90017
« on: May 05, 2007, 02:48:01 am »
Is anyone familiar with the sdl version of vba. For some reason it doesn't like long file names. Example when I try to run Double Dragon Advance (U).zip it gives me an erorr messange saying "unknow file type double" But when I rename it to double.zip it loads just fine.
And before anyone asks why i'm not using the windows version it's because Sdl version runs much faster on my 400mhz.
unclet
Re: Visualboy Advance SDL rom naming question
« Reply #1 on: May 07, 2007, 01:20:10 pm »
I have never used the SDL version before but could it be possible you need to place double quotes around the complete filename when asking the emulator to run it?
ex:  "Double Dragon Advance (U).zip"
Without the quotes it looks like the emulator is simply considering the first word as the filename (ie: Double) only.  Other emulators have the same problem unless the double quotes are included in the command execution line.
Here is how I execute the Visualboy Advanced emulator manually:
  visualBoyAdvance "C:\Emulators\GameboyAdvance\Tekken Advance.zip"
Thought I would mention it .....
« Last Edit: May 07, 2007, 01:26:52 pm by unclet »
gonzo90017
« Reply #2 on: May 10, 2007, 04:35:14 pm »
Thanks that worked great.
unclet
« Reply #3 on: May 10, 2007, 05:07:48 pm »
excellent!   :applaud:
