Author Topic: B+D 6v drill battery replacement?  (Read 3226 times)
« on: May 04, 2007, 09:37:50 am »
I have a low end B+D 6v cordless drill.  It's not very strong but I like to use it for electronics work, makes opening cases and such very quick.  The battery isn't the swap in type, it's built inside the handle.  Can you replace the battery on that type?  I have emailed B+D a couple times with no response.  If I could pick up a cheap replacement battery, it's worth saving, but if not I may as well drop a little cash for another small cordless.
« Last Edit: May 04, 2007, 09:42:01 am by ChadTower »
fatfingers
  • Got UltraStiks?™
Re: B+D 6v drill battery replacement?
« Reply #1 on: May 04, 2007, 09:58:37 am »
I don't know anything about the drill, but in my experience you should take it to a pricey store like Batteries Plus and they'll probably give you a good idea if they can replace the battery or not.  Now, whether you'll want to spend that much is another story.
Good luck.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
« Reply #2 on: May 04, 2007, 10:03:39 am »
Yeah, it's only like a $25-30 tool, but it works very well and is in excellent shape, so I hate to just toss it because the battery sucks.
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
« Reply #3 on: May 04, 2007, 02:45:08 pm »
You'll probably have to make a phone call to B&D if you want any response. Usually, the batteries are the most expensive part of the tool and not worth replacing  :(
« Reply #4 on: May 04, 2007, 02:46:06 pm »
That's what I figured.  This battery sucked, I sure as hell didn't do much to wear it out.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #5 on: May 04, 2007, 10:12:49 pm »
Check these guys out.
It's 9am. I'm calling it a nite.
« Reply #6 on: May 05, 2007, 10:01:40 am »
Thanks, email sent.
