Author Topic: Wii Remote dropping sync  (Read 2671 times)
ClubNinja
  • Last login:October 19, 2010, 12:46:02 pm
  • Comfortably Numb
« on: April 20, 2007, 02:44:58 pm »
I've had my Wii since launch. Since about 15 minutes after launch, I've had the same two remotes synced to it. Last night, in the middle of use (navigating the channels screen, nothing intense), the remote I was using just stopped responding. The batteries were fine, probably replaced a few weeks ago actually. Regardless of what button I pushed, all four blue LEDs on the remote would flash together.
So, I tried to resync the remote and had no response. Deciding to worry about it later, I grabbed remote 2. Same thing. Wouldn't respond to a sync either. I've gone through the online troubleshooting and, after having done everything Big N suggests, they recommend that I may have to ship the console to them for repair. Not something I'm terribly excited about having to do.
Has this happened to anyone else, and if so, what was the outcome?
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
Re: Wii Remote dropping sync
« Reply #1 on: April 20, 2007, 02:51:53 pm »
Pull the AC for a minute then plug it back in and try again.  It's happened to me once and this cleared it.  Did they not suggest this?  I've seen other reports of the same problem and solution in various places on the net.  I'd be surprised if Nintendo hasn't heard about it.
MustardTent
  • Last login:February 22, 2015, 12:14:02 pm
    • Blog
« Reply #2 on: April 20, 2007, 03:24:58 pm »
Have had the exact same thing happen to me.  Like Samstag said, all I do is pull the power for a few seconds.
Daniel270
  • Last login:April 10, 2011, 12:34:14 pm
  • Older Than PONG!!!
« Reply #3 on: April 20, 2007, 03:42:54 pm »
I didn't have to pull the plug out for mine... all I did was completely turn the unit off momentarily by pushing the power button til it turned red (same effect as unplugging it).  Wiimotes work again!
I think the Standby mode is pretty useless, actually......
I Haven't Lost My Mind, It's Backed Up On Disk Somewhere.
ClubNinja
  • Comfortably Numb
« Reply #4 on: April 20, 2007, 11:01:35 pm »
The unplug did it - thanks folks.
Forum - 1
Nintendo Support - 0
MustardTent
    • Blog
« Reply #5 on: April 24, 2007, 09:39:59 am »
It's not quite the same as unplugging it.  The only time that no power is able to reach the Wii is when you pull the power cable from the outlet.
However, if this ever happens to me again I'll try what you did.
Pongo
  • Trade Count: (+34)
  • Last login:July 01, 2015, 10:19:54 am
« Reply #6 on: April 26, 2007, 02:49:09 pm »
Sounds like you got it resolved, but I thought I'd chime in to say it happened to me too.
I originally thought it was something my 4 year old had done, but I've since talked to others and it seems to be quite common. In my case I was simply able to re-sync and things were back to normal. Fortunately, it has only happened once since getting the Wii (Early January).
sphetr2
  • Last login:February 08, 2009, 06:35:00 pm
  • black and white album
« Reply #7 on: April 26, 2007, 02:57:32 pm »
This happened to me recently, too. I think I read somewhere that if you hold down the sync button (on the wii) for ~30 seconds, it "refreshes" the bluetooth connection (or something). I did this and it started working again.
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #8 on: April 26, 2007, 04:07:21 pm »
The manual also talks about all of the things you guys are mentioning.
For what it's worth.
