Author Topic: REAM error on my Area-51/Maximum Force  (Read 5996 times)
deep-c
  • Last login:September 23, 2013, 12:18:54 pm
« on: April 18, 2007, 03:13:38 pm »
I have Area-51/Maximum force and my game just started acting weird, the game will start but a few moments into it the game goes into a diagnostics screen titled "REAM Error" and a bunch of code follows that and at the bottom it displays: "Three strikes and You're Out".  Do you know if this is a hard drive error?  I ran ROM checks and all memory is OK.  Has anyone heard of this before?
Regards, Eric
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: REAM error on my Area-51/Maximum Force
« Reply #1 on: April 18, 2007, 03:27:09 pm »
It needs lube.
NO MORE!!
grantspain
« Reply #2 on: April 18, 2007, 03:34:16 pm »
sounds like the hard drive,have you run all the diagnostic tests?
grantspain
« Reply #3 on: April 18, 2007, 04:45:08 pm »
i remember seeing this fault years ago but i can't remember the problem,its as if some sort of security problem has occurred
maybe best to contact midway directly
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: April 18, 2007, 05:28:27 pm »
Tap the Start button 3 times. Then let the game load. Check the power supply voltage to be +5.1-+5.25v. Then go to test mode and restore factory settings, clear the high scores, erase the EEPROM. This <u>might</u> clear the problems.
shadowolph
  • Last login:May 02, 2011, 01:35:36 pm
« Reply #5 on: March 25, 2009, 11:38:07 am »
I'm having the same problem. I have an Area 51/Max Force. I bought it from an arcade that was closing. It didnt work... one problen was the hard drive. I put a new HD in but now I get the REAM error. The screen comes up, I choose the game I want, then the mission, then sometimes it will let me shoot a few "bad guys" then the error code comes up, usually after picking the mission the error code comes up. when it does, I can hit the start button 3 times and the game select menu comes back up (to chose Area 51 or Max force) I have taken out and reinserted the 4 security chips incase there was a bad connection. I havent found the problem yet
red_johnny
  • Last login:June 03, 2011, 02:35:17 pm
« Reply #6 on: March 25, 2009, 11:42:43 am »
Hopefully you will get your answer here.  Good luck!
shadowolph
« Reply #7 on: March 27, 2009, 05:24:44 pm »
I ordered a new security chip, installed it and its working fine now.
I got it from
Arcade Services
4084 Pendleton Way # 269
Indianapolis, In 46226
Contact Phone
317-547-7041
Email address: arcadeservices1@aol.com.
red_johnny
« Reply #8 on: April 05, 2009, 06:27:58 pm »
Great news! :applaud:
Witchboard
« Reply #9 on: April 07, 2009, 08:07:27 pm »
I think ToplessZ sells those on this board.  The security chips that is.
