Author Topic: W.I.P. Jamma Test Rig *warning large pics*  (Read 7182 times)
smythe
  • Last login:June 13, 2010, 04:28:06 pm
« on: April 12, 2007, 11:47:56 am »
i know this aint a machine i have a large garage so i decided to build a decent test rig to save hooking up to a cab all the time....
loads still to do adding 1&2 player 1-4 buttons + 2 player joystick + a few other bits..
cheers
« Last Edit: April 12, 2007, 11:50:23 am by smythe »
Re: W.I.P. Jamma Test Rig *warning large pics*
« Reply #1 on: April 17, 2007, 09:31:03 am »
You don't have to build a huge rig with a dedicated control panel.  A very small one with the right amount of small buttons will do the same.  JAMMA sticks are just 4 microswitches, the buttons are just microswitches.  You can put a decent JAMMA test rig in a small space.  I've seen plenty of them in only a couple of square feet.  A power supply, an RGB capable 15khz monitor (old Commodore monitors are perfect, small, use house AC, and also accept RCA for regular TV), and a test panel less than a foot square.
smythe
« Reply #2 on: April 17, 2007, 03:42:44 pm »
hi
i wanted a large work surface to work & test boards ect
i also repair beer fonts & chip consoles ect on it i hate being in tight spaces ...
so i made a big thing so i could have say a pcb & a console in bits and a beer pump all at the same time + im having a new kitchen so all the old units are going under and over what you see...
also with the buttons instead of the sticks is ok but i like to play the games aswell :)
cheers
« Reply #3 on: April 17, 2007, 04:35:04 pm »
Fair enough, but watch out for that joystick, I saw one of those in hole in a movie once and you won't like where it goes.
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« Reply #4 on: April 17, 2007, 04:40:18 pm »
hahaha!!!
arcadefever
  • Miami Beach Florida
« Reply #5 on: April 17, 2007, 07:07:36 pm »
i dont have that much space, so i buid a small one....
http://www.arcadefever.net/MYPROJECT/test-bench/TEST-BENCH.html
i wish i had such a wide surface to work on it .....
 :laugh2:
« Reply #6 on: April 17, 2007, 08:49:56 pm »
Is that a tiny video screen?
arcadefever
« Reply #7 on: April 17, 2007, 10:42:56 pm »
yes 5"
Witchboard
« Reply #8 on: April 17, 2007, 11:21:21 pm »
Mine.  Still a work in progress, but functional.  Having a dedicated table like that will be very handy Smythe.  My workspace is small, so I end up working on something then going to the other room to plug it into my tester.  Hmm.. I should get more organized.
« Last Edit: April 17, 2007, 11:24:41 pm by Witchboard »
« Reply #9 on: April 18, 2007, 09:02:08 am »
yes 5"
Cool.  Is it using an RGB-composite adapter or does it actually accept raw RGB?  Not many tmall LCDs I've seen accept RGB.
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #10 on: April 18, 2007, 09:17:31 am »
Some of those 5" and 7" console LCDs can be hacked to accept RGB.
Quote from: saint
saint is all powerful.
Apparently he is.
2600
« Reply #11 on: April 18, 2007, 10:50:30 am »
That is one small CRT.
arcadefever
« Reply #12 on: April 18, 2007, 11:39:19 am »
yest it is a small crt...5" it accept RGB, but as been modified to work properly...
got it 2 years ago on ebay, for $40...
work perfectly, multy sinc  ;)
