Author Topic: Monitor Anode cracklingnoise/electricity seen coiming out  (Read 1631 times)
rfr341
  • Last login:May 24, 2017, 12:15:31 am
« on: April 06, 2007, 06:21:38 pm »
Hi , I have one of the cabinets which when it is turned on there is a crackling sound coming from the anode cap and you can see blue electrical light coming from under the anode cap. What is causing this problem.
cw
  • Last login:March 26, 2026, 09:24:03 pm
  • Game over man game over
    • The Cab
Re: Monitor Anode cracklingnoise/electricity seen coiming out
« Reply #1 on: April 06, 2007, 06:43:11 pm »
I get the same thing when games are out in my garage being worked on... most of the on rainy days it will happen. Moisture is getting under the anode cap. Discharge remove the anode, discharge again just to be safe, and then clean under the cap. Clean all the dust and spider webs off then use a clean dry shop towel to go over it once more.  You might also check the cap to make sure it has not been damaged.
rfr341
« Reply #2 on: April 06, 2007, 07:01:30 pm »
Excellent. Thanks for the info
Ken Layton
  • Guru
  • Technician
« Reply #3 on: April 07, 2007, 12:36:32 am »
Dry things off with a hair dryer too.
