Author Topic: Golden Tee trackball question  (Read 1484 times)
buck3480
  • Last login:August 28, 2007, 03:41:14 pm
  • I'm a newbie
« on: April 02, 2007, 03:16:11 pm »
I have recently come into possession of a GT 2002 machine that is non functional.  I'm wanting to MAME it but have a few questions.  Does anyone know if the current trackball (assuming it works) will work with an Omni-pak (sp?), or is there some "better" way to get it working with MAME and my computer.  Thanks for the help.
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
Re: Golden Tee trackball question
« Reply #1 on: April 02, 2007, 03:28:59 pm »
It SHOULD work with an Omni-Pac.  The trackball has 2 slotted discs with and emitter and receiver U-shaped unit.  As you spin the ball, it spins on rollers that spin the discs, creating spaced signals from the emitter/receiver.  You should be able to hook this to your optipac, as long as you provide a power source to the emitter/receiver unit so it will work.  Maybe the opti-pac provides this power source.  Dunno.
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
ahofle
    • Arcade Ambience Project
« Reply #2 on: April 02, 2007, 03:33:08 pm »
Yes, the optipac provides a 5V connection and ground.  It should work fine with it.
