Author Topic: Cleaning Arkanoid Spinner  (Read 1647 times)
Squeeky
  • Last login:February 17, 2012, 04:10:56 pm
    • Makre $220 for Free, Follow My Tutorial
« on: March 29, 2007, 11:45:52 pm »
Well I just got a Arkanoid spiiner in a group of parts I purchased.  I intend on using this for my mame cab, but I wanted to clean it up a bit prior.  There is plenty of brown grease stuff on the gears, but it is kinda noisy when spinning.  What is the best method use to clean and re-gease.  Also I know the Arkanoid spinner is extremely sensitive, would there be any issue using as a spinner for most mame roms.
Squeeky
ahofle
    • Arcade Ambience Project
Re: Cleaning Arkanoid Spinner
« Reply #1 on: March 29, 2007, 11:55:37 pm »
It's definitely better to be too sensitive than not sensitive enough.  You can always dial down the sensitivity in MAME for the other games.  The only concern would be your interface not being able to keep up with the spinner which would cause backspin.  How are you planning on hooking it up to your PC?
BobA
  • What Me Worry?
« Reply #2 on: March 30, 2007, 12:05:17 am »
You can use an automotive degreaser and then let dry completely and apply new grease.
Squeeky
« Reply #3 on: March 30, 2007, 10:36:10 am »
yes I plan on using it with Mame and connecting via mouse hack.
