Author Topic: Atomic FE & Joystick  (Read 7510 times)
SodaPopinksi
  • Last login:November 09, 2011, 03:38:29 pm
  • Cold, Smokey, Rich Diet Caffeine Free Coke
    • John Keeler
« on: March 24, 2007, 09:06:14 pm »
Hello, I just tried out Atomic FE and I'd love to use it on my next project, I especially like the animation abilities and the boot directly to game option, with a little messing around I was able to make some cool effects. The only thing I wish it had was native joystick support, since I can't get it to work with an Ultrastik using USB (correct me if I'm wrong on that one, but as far as I know the 360 acts like a gamepad in USB mode) without using joytokey and I'd like to not have to use that at all. I've noticed a few other threads now asking for that feature, if that feature is possible, that would be awesome!
"Seimitsu LB-39's make me thirsty"- SodaPopinski
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Atomic FE & Joystick
« Reply #1 on: March 25, 2007, 06:02:59 am »
This feature should come.  I have just ordered a USB Joystick to be able to implement that support.  So it should be here in the next major version.  But i have no date for the next version.
bfauska
« Reply #2 on: March 26, 2007, 01:50:42 am »
Good to hear.  I have been happy with mamewah, but having options is allways great and I really like the idea of animated intos and backgrounds.
Keep us posted. (I'm sure you will)
L8R,
B
SodaPopinksi
    • John Keeler
« Reply #3 on: March 26, 2007, 03:25:58 am »
Awesome! Glad to hear that will be implemented  :cheers:
Extreme8
  • Last login:August 24, 2008, 03:46:24 pm
« Reply #4 on: March 26, 2007, 10:27:47 am »
I dont have a U360 yet so I could be way off base here, but would it be possible to use the on-board interface in output mode and connect it to an encoder along side the USB connection?
That would give you the 4 digital outputs to control the FE, then when you loaded your map for the 360 you could disable those 4 outputs from the encoder so they weren't fighting the usb for control of the emulator.
Unless you're not using an encoder.... which I didn't think about until just now... In which case, never mind.
« Last Edit: March 27, 2007, 08:37:00 am by Extreme8 »
youki
    • Atomic Front End
« Reply #5 on: March 26, 2007, 10:33:50 am »
I don't know to much about the 360 for now.
But it is in my plan to support it as well.
shorthair
« Reply #6 on: March 26, 2007, 07:08:21 pm »
Sorta assumed one or the other would run - vs both simultaneously.  Have look through Ultimarc, or ask Andy on that one.
SodaPopinksi
    • John Keeler
« Reply #7 on: March 26, 2007, 08:11:04 pm »
You're right Extreme8, I just checked the site again, it can be set to Output mode with a harness to connect to an encoder and connected to USB for mapping at the same time! So it can work that way  :cheers: I thought it had to be set up as one or the other.
Kaytrim
  • I'm too nice a guy
« Reply #8 on: March 27, 2007, 05:58:27 pm »
It would still be nice to have this implemented.  I will have a Midway 49-way connected to a GPWiz49 as my main joystick.  Even though there is support for the GPWiz49 it is still not recognized as the main joystick without JoyToKey.  I prefer to have as little overhead as possible while having a nice front end.
youki
    • Atomic Front End
« Reply #9 on: March 28, 2007, 02:51:06 am »
Atomic has a basic support for PC Joystick in Front End mode . The problem is it is not configurable and limited.  I know it works with the GP49Wiz.
What did you choose for Front End mode for the GP49Wiz in AtomicManager?
Are you sure you GP49Wiz is detected as a joystick in windows?
Kaytrim
« Reply #10 on: March 28, 2007, 12:40:44 pm »
I tested the stick in windows before I did anything else and it does work.  I am not in front of my cab right now but I believe that I chose 4 way for the frond end mode.
I'll check tonight if I have the time.  I may not be able to get on this until after April 15th.  I still have to do my Income Taxes.
TTFN :cheers:
Kaytrim
youki
    • Atomic Front End
« Reply #11 on: March 28, 2007, 01:45:40 pm »
Try to put mode 1 or 2  (raw mode or progressive mode).
And on the option tab of AtomicManager.
Check  the checkbox :  Analogic mode for joystick
(in this mode more you press, faster the list goes)
Another thing, the Joystick must detected as Joystick 1 ...
Kaytrim
« Reply #12 on: March 28, 2007, 02:18:50 pm »
That is where the rub is.  My 49-way is detected as joystick 2.  I also have a GPWiz for everything else.  Looks like I am going to have to do some rewiring sooner that I thought.  I have a KeyWiz so I can swap cards without too much difficulty.  It is just taking the time to do it.  Thanks Youki.
TTFN :cheers:
Kaytrim
Kaytrim
« Reply #13 on: April 07, 2007, 12:19:43 am »
I have everything wired to the GPWiz49 and it is the only joystick detected.  I have set Atomic for analog mode and set the GPWiz49 mode to 1.  I can use the stick in MAME but it doesn't work in the front end.
Any more words of wisdom???
TTFN :cheers:
Kaytrim
youki
    • Atomic Front End
« Reply #14 on: April 07, 2007, 03:36:38 am »
Detected as Joystick #1  ???
Just in case try in another mode for he GPWiz mode. (like the 8ways)... just to be sure.
Kaytrim
« Reply #15 on: April 07, 2007, 01:04:13 pm »
MAME detects it as joystick #1.  I tried modes 1,2,3,4 and still nothing.  Am I still going to need JoyToKey or RBKey??  I am using the most recent version from your site.
Kaytrim
youki
    • Atomic Front End
« Reply #16 on: April 09, 2007, 02:11:47 pm »
It seems you will have to use Joytokey while in front end Mode.  But that's strange. I don't what happens with your config. :dunno
