Author Topic: K7000 Horizontal Deflection Failure  (Read 2344 times)
alexred
  • Last login:June 25, 2025, 04:21:24 pm
« on: March 12, 2007, 12:48:56 pm »
Here is the story.  I have a K7000 that came in a Double Dragon cabinet.  The monitor did not work when I aquired the cabinet.  The HOT was shorted.  I replaced the flyback, HOT, and of course the fuse and everything was great for awhile.  Then I decided to replace the switched power supply and somthing went awry.  It turns out there was some mouse chewed wiring hidden in the cabinet and somthing must have shorted.  The monitor went to a dot and died.
I have replaced the chewed wiring.  The fuse was blown and the HOT was shorted.  I replaced the HOT and fuse.  Now, the fuse does not blow but I am not getting any glow from the tube.  I am following the K7000 flowchart:
R301 156VDC
Lifted D10 No Change
Q11  156VDC
Q10 appears to test ok
R89 and R101 appear to test ok
Replaced IC2 No Change
Any suggestions for the next step?  I have a capkit I can put in, but I am hessitant to spend the time if there is somthing obvious to look for.  The monitor had been capped in the last 3 years before I got it.
Ken Layton
  • Guru
  • Technician
Re: K7000 Horizontal Deflection Failure
« Reply #1 on: March 13, 2007, 12:15:31 am »
This chassis is well known for many numerous bad solder joints. Check that first. Don't forget that capacitors, just like any electronic component can fail at any time for any reason.
flashdog
  • Last login:February 18, 2012, 06:10:58 pm
« Reply #2 on: March 19, 2007, 11:27:50 pm »
Did you check D19 to D22 for shorts? Just a thought.
alexred
« Reply #3 on: March 21, 2007, 08:53:31 am »
     I replaced the capacitors with the K7000 cap kit and repaired multiple tarnished pads and traces.  Applying power I heard some static and a click.  Progress.  I lifted d10 and have raster.  So now I will replace IC4 the voltage regulator and I should be good to go.  I am pretty sure that it was a blown capacitor that was preventing any glow before, but there sure were enough questionable traces to make me wonder.
