Author Topic: Your mame.ini file  (Read 2380 times)
Boz
  • Last login:March 23, 2025, 03:55:29 pm
    • Battle Chasers Upright Cabinet
Your mame.ini file
« on: March 09, 2007, 04:20:22 pm »
For those who have 360 type joys, USB trackballs, USB spinner, would you mind terribly posting your mame.ini? I'm having some trouble and would like to see yours to help me troubleshoot.
Thanks.
ahofle
    • Arcade Ambience Project
Re: Your mame.ini file
« Reply #1 on: March 09, 2007, 04:34:02 pm »
You may get more input if you describe what problems you are having.
Boz
« Reply #2 on: March 09, 2007, 05:13:17 pm »
At the risk of sounding really noob-ish. After months and months of building, my cab is finally in a position to actually play. I'm setting up the FE (GameEx). I'm using Andy's Ultrastick 360, a Happ TB with USB conversion, Slickstick spinner (USB).
My trouble is getting the right games to use the right controls.
Now, I read a post where it was said that the ONLY way to properly configure use of the controls was to use automatic device selection. Yet, some games don't recognize the joy and some don't recognize the mouse-based controls. I was hoping to avoid the necessity for the eyesore of having a keyboard and mouse to navigate windows and change ini files right in the middle of using the system.
Is this something that everyone does? Edits individual games?
# INPUT DEVICE OPTIONS
# ctrlr                   <NULL> (not set)
mouse                     0
joystick                  0
lightgun                  0
dual_lightgun             0
offscreen_reload          0
steadykey                 0
a2d_deadzone              0.3
digital                   none
# AUTOMATIC DEVICE SELECTION OPTIONS
paddle_device             mouse
adstick_device            joystick
pedal_device              keyboard
dial_device               mouse
trackball_device          mouse
lightgun_device           keyboard
ahofle
« Reply #3 on: March 12, 2007, 12:53:23 pm »
For starters you need to enable joystick and mouse in your MAME.ini (for all games):
mouse                     1
joystick                  1
Then go into MAME and start any game.  Press 'tab' and go to 'Input (General)' and map your player one stick directions and also map the common trackball and dial/spinner settings.  They should then be the defaults for all games.
Boz
« Reply #4 on: March 12, 2007, 02:58:52 pm »
Thanks for the response ahofle. Actually I found a solution for this problem I was having.
http://forum.arcadecontrols.com/index.php?topic=64103.0
